Rare they are! Can you build it? price shipped to 95963
Thanks
Sending you a PM, need to know if you are running 10 or 32 spline stuff, etc. We can do either but they are different.price for an INFINITELY CLOCKABLEsm465 to gm205 with the figure 8 face. shipped to 73040
No need to sell your 205, we can make the 2wd to round pattern adapter. Price would be the same as the original.Only after i sell my round pattern 205...:shaking:
For future reference can you do a 6 bolt 2wd th400 to round 205..It needs to be 2" longer than the factory
Thanks,
Mike
Are you looking for a clocking ring, or an adapter kit?Allison to a 263? clocking ring.
PM sent!can you make adapters to run a dodge 205 off a 2wd 700R4....pm me with price shipped to 14411 if you can
You would be best off getting yourself an NP 205 off that was mated to a TH-400 originally. This tcase will have a 32 spline female input which will fit the output shaft your transmission has. Depending on which output shaft your transmission has you may be able to bolt a factory adapter. Either way an adapter similar to the one highlighted in the post will get everything mounted together.so if you have a 2wd trans do you make a small shaft from thrans to tcase? im new to the 4wd lifestyle? what tcase would be best to put behind a th400 in an 82 3/4 ton chevy
