Your not searching hard enough. Look specifically in the Ford area and here in General 4x4.
But heres what I can tell you....
Your correct on all the info you have posted. Yes, the stubs should be 35 spline and if not they are easy to convert.
Check out Branik Motorsports. Theres a lot of options but this seems to be the cheapest by far. Almost 1/2 of what spidertrax wants. They have F450 UBH's machined to 8x6.5 pattern (or any pattern) for a REAL good price. The F450 unit bearing hub is the one you want. It guarantee's the outer stub is 35 spline. Other Super duty BJ 60's are 30 spline and depending on choice, this is how we convert to 35 spline. And yes that means the F350 30 spline unit and the F450 35 spline unit are interchangable. Then just simply make your choice of drive flanges or leave the manual hubs.
As for high steer, again theres a lot of options. Theres several comapines that make hi steer knuckles. And yes, again the F350 and F450 knuckles will interchange.
However rather that replaceing the knuckle/s, many are choosing the mill the passenger knuckle and set it up similar to a 44 hi steer. There's acctuatlly a good thread going here somewhere on it. Search for it.
I myself opted for OffRoad Unlimited's knuckle for the passenger side for it was well priced and exactly what I wanted.
As for redrilling the hubs yourself, I suppose that all depends on your skills son. :flipoff2: No, if you gonna tackle it with a hand drill and a sharpie you better leave it alone. However if you've got the right tools to do it precise as chit, do it.
