1 - 4 of 4 Posts
a full spool? it shouldn't be any different, the gears dont care what differential is in it, they still have to be set correctly.
as for a mini spool, it doesn't effect the gears..(but if you havent installed them yet the same setup procedure would apply..)
backlash is inportant no matter what your installing. but if its a mini you shouldnt change your gear position, like said above. if its a full spool and you dont move your pinion, if you put everything back the way you found it is should be good, run a little pinion primer on the ring gear and rotate it just to make sure you still have a good pattern. If you changed your r n p at the same time you installed your spool you will have to do a complete set up. good luck.
1 - 4 of 4 Posts
