Just got back from the MCR and had to be towed out from the slabs on sun. Truck ran fine sat. night as i towed someone up to the top of the slabs, then sun. it just wouldnt start.
Checked fuel- had pressure on the motor side before it went into the injectors.
Sprayed starting fluid down the airbox and it would start, but would die once the starting fluid was gone.
As I got dragged down thru gatekeeper, my bro had to keep spraying starting fluid down the box to keep me running so i could make it thru (aka..sam patton style).
As soon as i reached my trailer, the damn thing started right up. I still have to find some time to go thru the truck and double check everything (clogged fuel filter, fuel pump, loose ground, etc...), but anyone have any other ideas??
motor is a 98 3.4 tacoma
