1 - 18 of 18 Posts
I found a d-60 that is full float and the right width. It is a 16 spline axle. I sit totally worthless? I know the spindles would ahve to be bored out to convert to 35 spline but what about converting it to just 30 spline?
searched and damn near all 60 post are for front 60's :flipoff2:
[flamesuit on]
A 16 spline D60 is still a decent axle. The shafts are teh same diameter as the 30 spline shafts, just with a different spline profile. You can use 30 spline side gears and axles to go 30 spline, but that really isn't cost effective seeing how common 30 spline 60's are. BUT if you're planning on going 35 it'll cost the same to do it to a 16 as a 30.
Justin
[flamesuit on]
My 16 spline D60 ended up a 35 spline. If you're going to change the internals any way then its a good unit.
3d Artist for Hire!
mine will too eventually.
WMS said they will do the conversion by cutting off the spindles, and welding on 14 bolt spindles to accept the larger shafts.
I got a fullsize Bronco that I bought with a 16 sline 60 in the rear with detroit and 5.35 gears. Why anyone spent the money who knows? The shafts broke easy. It had a 460 and 38.5's. If the 16 spline are the same diameter as the 30 spline it would be a waste of time to upgrade to 30 spline, because I never had a problem with the splines when I broke a shaft. The shafts never broke at the splines nor did I ever notice twisted splines.
Though not impressive on paper, my 16 spline rear 60 held up for over a year of abuse on 38's, welded diff, with a 460. I eventually broke two teeth on the pinion. I was going to bore out the spindles to use D70 35 spline axles. Doing that can be done.....but I located a Dana 70 U rear axle and used it instead.
My advice: If you have the 16 spline axles, run them until they break....that was my plan....and they didn't break. I still have both of mine...plan to put 'em on ebay in the near future.
Buford
rokcrwlrtj said:
it is 17 spline so i would have to change it over to 30 to lock it.
Get a welder...
locker problem solved...
rokcrwlrtj said:
yup, but mine is already 60" wms-wms so i will not be cutting it down. If i was then i would do the 14 bolt spindles etc.
You don't have to narrow the axle to put 14 bolt spindles on.
Some of the 16 spline 60s used too small a spindle to bore out for 35 spline axles. If you are planning on changing the spindles anyway, no big deal. If you are planning on getting the spindles bored you might want to check to make sure that you have a spindle that is big enough to open up before you get too involved in the process.
Gus
Discussion Starter · #16 ·
I will be sticking with 30 spline for now. It is going behind a 2.5l motor and only 35 inch tires till I can build a front as well then probably 37's.
I tihnk the 30 Spline will work just right because i will only be pushing 150HP and 190 lb-ft of torque through it.
Discussion Starter · #17 ·
I can finally say :flipoff2: to the d35.
1 - 18 of 18 Posts
