1 - 11 of 11 Posts
Title basically states it.
The tank I'm talking about is the in the cab style. Here is the tank I'm talking about:
Longer:
I'm doing a project(FJ55) that this tank will fit nicely and is priced nicely new. I will have the tank external of the cab I am creating.
I'm looking to do a TBI conversion and really want to have the pump in tank. Last two EFI conversion I did with external pumps sucked because of the overly loud pump whine. Loud enough to hear over the exhaust.
blatant asshole
Sure, im sure any number of chevy resto places offer a factory conversion. As well as mfg your own from a tbi setup.
Or just use any one of a fist full of suitable external pumps like the common walbro.
I am looking to do something similar in the same tank. I have not found anyone that has done it or offers a tank for that.
I think you could use a modified pickup tube, or cut a hole next to the stock location. I have not had a chance to measure a tank to confirm, though.
All the chevy resto places swap to a rear mounted tank.
Discussion Starter #4
As noted, I've already used 'suitable' external pumps and they all sucked. Extremely loud and annoying. I could always turn the radio to max or run a straight exhaust to over power it:laughing:
So far, my quick bing search has shown the same results: swap to rear mounted tank for EFI.
I was thinking the same thing for modifications... cut the stock location out, weld in a flat spot on top with ~3" hole, then use a bunch of thread serts and a retaining ring to secure the pump.
The number I found for the tank was: 60" wide, 16 3/4" tall, 7 1/4" deep
I am wanting to understand how big that flat section is, so you wouldnt have to modify the whole tank.
I have been looking at the holley efi setups. They arent cheap, but are fairly easy to install (dont need the nutserts and rings). Something like this, if it would fit: https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/in-tank_retrofit_fuel_module/parts/12-136
But you might could use the stock pickup with a Holley (or other) intank pump, similar to how they make these: https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/muscle_car_efi_modules/parts/12-308
From what I have seen, the new repop tanks have a seperate return inlet built it, so that you can run EFI. 71+ also had an extra vent line, iirc.
Discussion Starter #6
I had a custom gas tank made for one of my FJ55s. It was a square baffled aluminum tank. I used a 99 Camaro fuel pump assembly:
The tank was 33"x29"x10" or about 40 gallons
As you can see, I used the method I described. It has no leaks and no smell what so ever.:grinpimp:
My thought with the in cab tank is to cut the stock sending unit recess out and weld in a flat piece of metal to provide a flat spot for a similar mod as above.
I would then use a stock S10 pump assembly with potentially longer legs to reach the bottom of the tank. The Camaro pump is shorter than the S10; 10" versus 15".
Discussion Starter #8
I did it on '71 with a Holley terminator. Custom set up as I couldn't find anyone that made a kit at the time.
See post #10 in the thread linked below for the details.
https://www.pirate4x4.com/forum/chevy/2360609-ua-2016-prep.html
Thank you VERY much for the link and information. For future folks here is direct link to post:
https://www.pirate4x4.com/forum/37595945-post10.html
Who's bulkhead fitting did you use for the external of the tank?
How is the Hydramat working for you?
Glad I could help!
The bulk head I used is from Tanks Inc. It worked out, but isn't the easiest thing to install. There is a ring that goes into the tank and several little screws that draw the ring up and sandwich the tank. The holes have to be drilled very accurately to prevent binding. The threads on the ring are pretty soft and I stripped one of them cause it was really difficult to get everything lined up.
Holley now makes a module that looks really nice. It looks bigger than the Tanks Inc part, so it may be difficult to fit.
https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/efi_fuel_pumps/in-tank_retro-fit_fuel_module/parts/12-136
The Hydramat is awesome! It will drain the tank completely dry. The return line is set up to flow right onto the mat. So even with the tank low I have never had fuel starvation at extreme angles.
Glad I could help!
I helped a friend install the Holley setup in another vehicle. The way it tightens down is very nice. The downside here is, the hole you drill into the tank is the same size as the OD of the ring it looks like you used (based on the Tanks Inc site). Not sure if there is enough room for the cap to fit tight and seal.
Im guessing that nothing in your setup bothered the factory send unit/float?
1 - 11 of 11 Posts
