1 - 20 of 38 Posts
i found a 78' f 250, it has leaf springs front and rear...so that means that the front is a 44 and the rear is a 60 right? is the 60 a full-floater? it has 8 lug bolt pattern, if that is any help. won't the spring pads line up with my YJ?
what is the best way to tell if it is a full floater? and what is the best way to see if it is a dana 60?
i have already bought some bronco axles, but will the knuckles from the bronco fit on the f250, i have already had them tapped and ready for hi-steer?
Front may be a Dana 60...we pulled one off a 78 Ford F250 not too long ago. Look at housing. If you have a Dana 44 already it will be substantially larger. The U joints will also be huge compared to the Dana 44.
<IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/eyemouth.gif" border="0">
Discussion Starter · #11 ·
so now i am not going to be able to use smaller u-joints like i planed? i was hoping to make my rear drivshaft a fuse....
i got a dana 60 du-da du-da!
i really hope the front is a 60 too! that would be awesome!
Sorry but the front is a HP44. its still a good find but its no HP60. as for the 60 rear they are a dime a dozen with the 30 spline axles. a factory 35 spline tho would be a keeper.
Discussion Starter · #13 ·
sh!t, dime a dozen...you must not live in Michigan!! I am lucky that i found it before they smash it! <IMG SRC="smilies/smile.gif" border="0"> oh well, it is better than the 9" that i was going to use <IMG SRC="smilies/smile.gif" border="0">
It sucks that you live in the rust belt. How many would you like me to send you? I can get them for as little as $50. I could literally spend all day pulling them every day of my life and still not empty every junkyard near my house. <IMG SRC="smilies/smile.gif" border="0">
J. J.
There are 78-79 F250's out there with a R60 front. They were I believe rated at over #8500 gvwr. Rare but they do exist. Those were the days before ford had an F350 FWD. Plenty of Two by F350.
Living in Michigan may be to your advantage. Ford has certain suspension setups where the F250 had a Dana 60R for snow plows etc. So the B.S. about them not having a Dana 60 front is wrong <IMG SRC="smilies/wink.gif" border="0"> Some did.
If that one has one that is a hell of a deal.
Banned
Originally posted by patooyee:
<STRONG>It sucks that you live in the rust belt. How many would you like me to send you? I can get them for as little as $50. I could literally spend all day pulling them every day of my life and still not empty every junkyard near my house. <IMG SRC="smilies/smile.gif" border="0">
J. J.</STRONG>
you must be in heaven
Discussion Starter · #20 ·
michigan is key, haha <IMG SRC="smilies/laughing.gif" border="0"> even if it is not a dana 60 front, the 44 is better than the one i got off of the bronco. it at least already has the spring perches in the right place and don't have to grind that radius arm crap! <IMG SRC="smilies/rolleyes.gif" border="0"> and it probably has 4.10's too <IMG SRC="smilies/smile.gif" border="0"> that will be good for at least a couple monthes <IMG SRC="smilies/smile.gif" border="0">
i wished i lived in heaven too <IMG SRC="smilies/biggrin.gif" border="0">
1 - 20 of 38 Posts
