1 - 20 of 34 Posts
1750$$ OUT THE DOOR .....82" IN BETWEEN WHEEL WELLS ....16FT...ONE AXLE WITH BRAKES....7000 LB..UMMMMMMMMMM.WITH RAMPS.......THEN 120 FOR THE BRAKE CONTROLLER AND 69 FOR INSTALL.
FROM CONCORD GARDEN EQUIP.....
seems high to me... I bought a 20' gooseneck with 2 braked axles and ramps for 1250... that's kind of an extreme example... and it's a home made trailer... but I also bought an 82" wide 16' utility trailer with one braked axle for 650 here in Texas...
Doug
I MEANT TO SAY .......
IS THIS A GOOD PRICE......
YEAH THIS IS AFTER TAX AND REGISTRATION........:flipoff: DMV....
BEFORE THAT IT WAS 1395$$
Does yer dewg bite?
I take it the Fj is not a daily driver anymore :flipoff2: :flipoff2:
Discussion Starter · #10 ·
HEY VULVA :flipoff2: STILL GANNA DRIVE IT ..........JUST LOOKIN TO SEE WHAT I CAN GET.......
HEY YOU GET WHAT.........:flipoff2: ...FINALLY SOLD THE CAMARO........SELLING MY 4 RUNNER TOO .......PICKING UP MY EXTENDED CAB TONIGHT:D
I WENT TO LOOK AT A FEW TRAILERS .......WHAT A BUNCH OF CRAP......ANGLE IRON AND AXLES......
ILL PROBABLY MAKE MY OWN......SAVE ABOUT 1000$$
Discussion Starter · #12 ·
1..........mmiiiiiiilllllllllllllllllliiiiiiiiiooooooooooooooooooooonnnnnnnnn
dollars
na really like 8k......just wanted that thing outa here.....the motor needed to be pulled to replace the headgaskets and i didnt want to get my hands dirty:D
Does yer dewg bite?
Sweet truck :flipoff2: It'll be a nice change to have doors for you :D
Yeah I know what you mean. California tax and the DMV will bend you over big time. That's one reason why I moved 6 years ago. I miss the desert and my freinds alot but I don't miss getting bent over whenever I want to do something. Here in Tennessee it's 25 buck's for tags nomatter what you have,a $150 pacer or a $50,000 truck is $25 bucks for tags. Trailers don't require tags unless it's for a commercial buisness:D :D
When I was shopping for trailers that was about the best price I found in Northern California. I ended up getting one from Aztex where they are made in SoCal It was 1350 out the door including tax and permanent registration same specs as yours. You can do similar in Carson City I hear.
Price sounds right on the trailer, but they are smokin crack on that controller. Buy a controller somewhere and post up in the towing forum. I will tell you how to put it in.
You may beat that trailer price at another lot, but don't expect a couple hundred dollars. Trailers don't have a great mark-up to begin with. You might see a $50-100 price break. Tell those guys that you will take that trailer, at that price, if they put brakes on the other axle.
Discussion Starter · #18 ·
1BADROCKTOY..........WHERE WAS THAT AT.....??
PHONE##???
You might want to check what out you can buy at southwest They have decent prices, I got a second set of trailer brakes from them paid $70 a side. It included everything seals, bearings, cotter pin.
I got my controller. and the '03 GM wiring harness for $132. Install was plug in one side of connector to dash, plug in the other side of connector to prodigy
- Keith
1Badrocktoy said:
Just bought a new Carson trailer paid $950 , $1150 out the door , no trailer brakes #7000 , I'll just add the brakes from a local shop for $140 do the work myself and call it good:)
That's about the same price I paid for similar in FL. I suspect you can find one new w/o brakes for ~1K and put them on yourself easy enough.
1 - 20 of 34 Posts
