1 - 6 of 6 Posts
ive got fuel. i have replaced the cap coil rotor distibutor cps ecu and still it wont start!!!!! i done everything i can think of but it wont spark. it wil crank but thats it.
94 cherokee sport
4.0 HO
There is an Automatic Engine Shutdown fuse in the engine compartment fuse box. It is one of the small blade fuses, check it. The engine will crank without spark if it is the problem.
It will blow if there is a short in the OBD ll sensors or the injector wires, heck, sometimes it just seems to blow just to get you stuck out in the middle of noplace...
Ask how I know!
Rick
no spark sounds like a bad CPS...just cus you have replace it dont mean you got a good one to replace it with, i went through two (2) of them from advanced then went to the stealership...that one worked!
ok i just replaced the cps for the third time. and it still wont start!!! can anyone in sacramento come take a look at it?
1 - 6 of 6 Posts
