We are now making mounts for JAZ fuel cells. Our first is the 16 gallon 270-016.
Introductory pricing is 20% off our regular retail price of $134.99. We'll run this great deal until the end of the month.
AVAILABLE NOW FOR $107.99!
The JAZ 270-016 Fuel Cell Bracket is designed to add style, simplicity, and strength in securing your fuel cell. Don't compromise your safety; secure your JAZ fuel cell with this Artec Fuel Cell Bracket. Get a mount that's more stylish than two straps of steel.
Features two CNC cut, bent, and dimple died tops cut from 16 gauge cold roll steel, two 10 gauge side brackets, and two 10 gauge bases for uncompromised strength. Bases are shaped like c's to allow notching for tube chassis. For flat surface mounting such as in a truck bed, simply don't use the bases. 6 pieces total. 1/4" hardware included.
Fits 16 gallon JAZ fuel cell model 270-016 which measures 26Lx18Wx10H. Works for foam or non-foam variations of this fuel cell. Bare steel finish, requires paint, powdercoat, or plating to not rust. Bolt holes on top mounts line up to bolt holes on flange of fuel cell. These tops are wide enough to allow additional bolt holes to be drilled across the flange for extra security which is recommended for high speed racing.
WE ARE NOW TAKING REQUESTS FOR OTHER JAZ FUEL CELL MOUNTS. Please include the MODEL NUMBER in your request since they make various versions for the same volume. The most popular sizes will be designed first.
