1 - 20 of 26 Posts
Vendor
JD2 MAD Series Cutting Tables
Sizes: 4x4 - 4x8 - 5x10
MAD 4x4 - List $15,950 / Factory Direct $12,950
MAD 4x8 - List $18,950 / Factory Direct $15,950
MAD 5x10 - List $21,950 / Factory Direct $18,950
Features:
- Welded base is made of 3/16" steel plate construction.
- Base is supported by 4" x 3" x 1/4" wall steel legs with 30mm leveling pads.
- Adjustable slat height adjustment and slat configuration.
- Beams (Y-Beams) are made out of 4" x 3" Box tubing 1/4" wall and machined in a twist-neutral jig.
- 3/4", 16 pitch spur gear on the Y-Beam provides precise alignment.
- The spur gear is driven by a 10:1 high precision gear box.
- The Gear Box is driven by a USA made Brushless Servo Motor.
- Rapid speeds 1,000+ inches per minute.
- Rollers have an 8,900 lb. capacity with a dual-row radial ball bearing which carries the 300 lb. Y-Carriage and Gantry setup.
- The gantry is an Aluminum structure with precision machined weldments. Complex milling processes ensure that the gantry has perfect angles, flat surfaces, and holds the spur gear perfectly vertical.
- The Z-axis rides on a 25mm linear guide
- Magnetic break away to ensure the system powers off when the torch is disengaged.
- Switches provide Initial Height Testing and a Z-Homing Process to ensure accuracy.
- Computer included (Computer, Mouse, and Keyboard)
- Includes SheetCam
* Plasma Unit not Included with MAD Series Cutting Tables.
Please send a message or email [email protected] to get a shipping quote. Thanks!
Vendor
What are the cutting speeds?
And since you guys are new to the plasma cnc world, what do you offer that others don't to justify the higher price? I'm looking at an Arclight table that is a fair amount less expensive.
Vendor
Discussion Starter #6
The cutting ipm will depend on the plasma unit and thickness of the plate. The rapids on the MAD series is just over 1,000 ipm.
We use very heavy construction for the base at 3/16" thickness plate. The machine has USA made Brushless Servo Motors that run through high precision gear boxes which allows us to get the accuracy needed. The gantry is a structure with precision machined weldments.
Not to mention we offer SigmaNEST Companion software with the machine that has a value of $4,950.
Are motion control board is made in house so if you ever did have any trouble we are the manufacturer of that.
These are just a couple of things our table offers.
Vendor
Whats the discount if purchased without software? I have software that works perfect for me
Vendor
Discussion Starter #8
We don't offer any discounts because everything is sold as a package right now. The value of the SigmaNEST is approx. $4950 and is installed on every computer we ship out.
Vendor
Discussion Starter #12
Down-Draft Air Box - $200 each
Features:
- Currently includes SigmaNEST Companion Software which includes automatic TrueShape nesting, optimized tool-path generation, and built in CAD tools. http://oem.sigmanest.com/Content/Companion.PDF
- Table ships fully assembled and tested.
* Available Down Draft Box that attaches to the base. (additional charge)
Vendor
Interesting
Care to share the setting ?
1 - 20 of 26 Posts
