1 - 4 of 4 Posts
Mains- 80 ft lbs
Rods- 33 ft lbs
Pan- 1/4 inch bolts, 80 inch lbs & 5/16 inch bolts, 11 ft lbs
Head- 110 ft lbs (22, then 45, then 110 sequence)
Valve Cover- 85 inch lbs
for the head start in the middle and start making a circle working your way to the ends, and one of them needs to have sillicone on it and torqued to 100. i believe it is the front most on the driver side.
Bolt number 11 gets Loctite 592 or equivelant. It's torque is 100 ft lbs, and it is the front most bolt on the driver's side.
1 - 4 of 4 Posts
