1 - 20 of 47 Posts
It was running fine until I stop for a quick bite on Sunday, then no start! It does not crank at all. The voltmeter read 10 volts, so I figured the battery must have been drained. Tried jump starting, no show.
I recently changed the battery, so bad battery can be eliminated. How to go about troubleshooting this? :confused:
Any input would be much appreciated. :D
My Jeep: 1989 Sahara Wrangler
There is definitely a click and the voltage drops from 10-11 volts to zero. The voltage comes back up after a minute or so, then the same things repeats if I try to start.
Whack on the starter with something fairly hard 3-4 times, then try to crank it. That may loosen it up if it's bound, but it sounds like you will have to replace it.
Discussion Starter · #13 ·
Two bolts holding the starter, two nuts holding the pos/neg wires.
Done in less than 5 minutes.
About $75 for a starter.
Awesome thanks, is solenoid a part of this as well, or do I need to buy this separately? ( sorry, never done this before so it might sound silly).
It's all one piece, I have seen a few issues with the starter, A buddies XJ had the same issue and the wire from the starter to the battery was shot.
haha ok that wasnt very helpful. i googled e 12 and it doesnt come up. what im talking about is an external torx drive size 12. your bolts if stock will be a funny little star shape and thats the tool you will need.
Discussion Starter · #17 ·
All the bolts on my Jeep are funny one off looking. So, I went ahead and bought a whole set of star shaped drivers. Not sure what they call them...
:shaking:
:shaking:
Damn guys, there called Torx Bolts
And by the way I hate them
Discussion Starter · #19 ·
Ok, guys, I need your help on this again. I removed the starter and got it checked by Pepboys. It came out clean, they say it has no problems at all. I’ll get it checked by AutoZone( just in case).
I installed it back and I see the same issue again, that is when I turn the ignition, there is “click” noise and that’s it. Sorry to bother "again", how do I even being to check the wiring???:(
1 - 20 of 47 Posts
