1 - 10 of 10 Posts
Richard w said:
That is what I thought at first but what got me was the 60.5" width, I thought the full size were aroung 65" ??
R/T
The axle in the "full size" Jeep is not the same as a full width truck axle. The axle you have is more compared to a stock YJ axle width. We use them a lot in YJ's to keep the axle width very close to the same. Makes for an easy swap. A good axle to use for the rear is a Rodeo axle. It is the same width, same lug pattern, is a Dana 44, has 4:10 gears, and has disk brakes. If that helps.
-Dan
Full size jeep Wide Track axles are about 65" Full Size Jeep Narrow Track which is different than CJ wide track vs Narrow Track is like Dan said. what you have, a Good axle to keep stock width in a CJ or YJ
-Paul
1 - 10 of 10 Posts
