1994 JEEP YJ
1.75 DOM CUSTOM CAGE (4 SEATER)
NEW CORBEAU FRONTS AND BENCH REAR (MOUNTED IN JEEP WILL NEED DUST CLEANED OFF THEM)
2 WINDSHIELD FRAMES. *1 WILL NEED NEW GLASS
BESTOP SOFT TOP BLACK (GOOD USED CONDITION) *BESTOP 2 PIECE SOFT DOORS TAN (PLANNED TO BUY TAN TOP TO MATCH) * LIKE NEW
ALL SOFT TOP HARDWARE AND RAILS ETC..
RCI FUEL CELL FOR REAR (NEW)
GRANT STEERING WHEEL, QUICK RELEASE, AND D SHAFT (NEW)
B&M PISTOL GRIP SHIFTER (MODDED FOR NO REVERSE LOCKOUT) NEW
CUTTING BRAKES (NEW)
BRAIDED STAINLESS FUEL LINES TO PLUMB ENTIRE JEEP. *ALL NEW
ALL AN FITTINGS TO PLUMB ENTIRE JEEP
USED MSD FUEL PUMP FROM LAST MOTOR
NEW CHASSIS WIRING HARNESS INCLUDING HEADLIGHT AND IGNITION SWITCHES
NOVAK ALUMINUM RADIATOR NEW
HOWE PS RES WITH FILTER
ORBITAL VALVE AND MOUNT PLATE
JOINTS FOR STEERING SHAFT
STEEL SLIDERS AND GEN RIGHT REAR COMP FENDERS
AUTOMETER ULTRALITE II GAUGES *ALL FULL SWEEP (TACH, SPEEDO, FUEL, WATER TEMP, OIL PRESSURE, VOLT METER) *
79 FORD DANA 60 FRONT NEVER RAN
-YUKON CHROMO 35SPLINE INNER AND OUTERS
-YUKON SUPERJOINTS
-LOCK RIGHT LOCKER
-YUKON 5.38 GEARS
-SOLID MANUFACTURING OUTER KNUCKLES AND STEERING ARMS
-BROACHED SPICER LOCKOUTS FOR 35SPLINE
-UNDERCOVER FABWORKS TRUSS
-MIKE ADAMS DE STEERING RAM
-3/4 TON BRAKE ADAPTERS FOR CHEVY CALIPERS
-ALL NEW BEARINGS INSIDE AND OUT
-NEW STUDS TO MATCH REAR AXLE
-GLO DIFF COVER WITH EVERY OPTION AVAILABLE. *BOLTED TO THE TRUSS
98 FORD DANA 60 REAR FROM VAN
-YUKON 35 SPLINE AXLES
-ARB LOCKER (REBUILT BY ORC) WITH PUMP & SWITCHES
-YUKON 5.38 GEARS (SETUP BY ORC)
-1/2" PLATE FULL WIDTH TRUSS
-DISK BRAKE AXEL (HAVE NEW CALIPERS *NEEDS ROTORS)
-GLO DIFF COVER WITH EVERY OPTION AVAILABLE. BOLTED TO THE TRUSS
4 LINK STUFF
- REAR IS LINKED ALREADY
- FRONT AXLE IS TEMP MOUNTED
- 4 7/8 HEIMS FOR FRONT UPPER LINKS WITH CONICAL WASHERS ETC... NEW
- 4 1.25 HEIMS WITH REDUCERS
- 8 BALLISTIC FAB 1.25" CARTRIDGE JOINTS WITH SERVICE TOOL NEW
- DOM TUBING FOR FRONT AND REARS COMES WITH JEEP. *2" 1/4 WALL, 1.5" 1/4 WALL, 1.75" 3/8 WALL *( PLENTY TO GET THE JOB DONE)
- COMES WITH ALL WELD IN BUNGS FOR THE LINKS
4 SWAY AWAY 14" REMOTE RES COIL OVERS WITH 1 SET OF TENDER COILS ( NEED 1 MORE SET) AND DUAL RATE KITS *(NO SPRINGS) *NEW
4 4" AIR BUMPS REBUILT *2 SWAY AWAY AND 2 FOX. *ONE SET OF CANS TO MOUNT THEM INCLUDED
TABS TO MOUNT
DRIVETRAIN
- 2004 LQ9 COMPLETE WITH ALL ACCESSORIES FROM ESCALADE WITH 10K MILES
- COMPLETE WIRING HARNESS *AND PROGRAMMED COMPUTER(FROM GUY THAT EVERYONE USES....CANT RECALL HIS NAME)
- FBODY OIL PAN WITH LOKAR DIPSTICK
- CERAMIC COATED HOOKER HEADERS
- TH400 HD FROM MILITARY TRUCK
- REBUILT WITH RMVB AND COMPRESSION BRAKING FROM TCI
- HAS ROUND PATTERN TAILHOUSING
- PTC CONVERTER SETUP TO BOLT TO LS ENGINE(ORDERED 1800 STALL)
-ATLAS II 3.0 (NEW)
- 32 SPLINE FRONT AND REAR
- 1410 YOKE FOR REAR
- 1350 YOKE FOR FRONT
- CABLE SHIFTERS
4 RED LABEL CRAWLERS (NEW) MOUNTED ON TRAIL READY HD ALUMINUM BEADLOCKS (NEW)
I'M SURE THERE IS STUFF THAT I AM FORGETTING BUT THIS IS MY BEST EFFORT. *THE JEEP IS A ROLLER AT THE MOMENT BUT DOES NEED TO BE COMPLETED. *NO STEERING IS IN IT, *FRONT AXLE NEEDS TO BE LINKED, NO DRIVE SHAFTS. *
PLEASE CALL ME IF YOU ARE SERIOUSLY INTERESTED. * I AM NOT POSTING PICTURES OF ALL INDIVIDUAL PARTS AND PIECES.
THIS IS NOT A PART OUT!!!! WILL UPDATE THE LISTING IT DOES BECOME ONE. *NO POINT IN ASKING RIGHT NOW.
$14,000
BRENT *205-413-6970
[email protected]
-YUKON SUPERJOINTS
-LOCK RIGHT LOCKER
-YUKON 5.38 GEARS
4 LINK STUFF
TABS TO MOUNT
DRIVETRAIN
-ATLAS II 3.0 (NEW)
- CABLE SHIFTERS
$14,000
BRENT *205-413-6970
[email protected]
