1 - 12 of 12 Posts
i need a transmission that will bolt up to in a 1974 CJ-5 to an amc 258 with dana 20. I would considar different t-case choices. I dont want to fool around with any fab work, I just want to bolt it up and go. Im looking for a transmission with a first gear ratio of >= 4 to 1. Thanks
~Riidel
I thought 74's where 232, is that a stock engine?
I will have T-18 ready to go in a couple weeks with D20, all rebuilt, D20 has 2.46 low range :flipoff2: . Let me know
-RJ
I have a T176 that shifts very smoothly- I can include the bell housing if you like. The transfer case is a Dana 300 so I would check to be sure that a D20 will fit. I believe that the first gear ratio is in the high 3's. $150 plus shipping.
Thanks,
Andy
Yes, I had originally planned on installing it in my Jeep, but have since decided to put a N4500 in there. I bought the tranny over the summer but haven't had time to get to it. I also bought the rebuild kit for it so it will be rebuilt with zero miles on it.
Are you in a rush for it?
-RJ
I HAVE BELLHOUSING TO GO WITH T 18 THAT WAS BEHIND A 258 I AM NOT SURE IF ITS THE SAME PATTERN AS CJ 258 (I ASSUME) TO GO WITH THE TRANS AND TRANSFER CASE I LISTED EARLIER DO YOUR RESEARCH I DO NOT WANT TO SELL YOU SOMETHING THAT DOES NOT WORK
1 - 12 of 12 Posts
