1 - 20 of 139 Posts
Vendor
You may have noticed a couple builds here on Pirate using this kit. Jesse Haines used the kit last year for a KOH YJ build. I want to go ahead and address a concern some people ask about. The skid plate drop essentially the same as the factory YJ skid plate. It looks deeper because the side have a 90 degree bend rather than a taper inward. This was done to allow the lower rod ends the space needed.
The kit is very simple to install. Once the factory spring hangers are removed you bolt the link mount sections to the factory skid plate mounting locations. The attach the skid plate we provide with the kit. This kit does require welding to the frame. It is NOT a simply bolt in kit.
The Motobilt YJ 4 link mounting system can easily be modified to a front 3 link if required. A couple customers have simply removed the upper link mount on the front not being used.
The kit was designed with a wheelbase range of 104 to 118 inches in mind. The upper link mounts do offer adjustment by means of multiple mounting holes.
The link mounts were built with strength in mind. They are completely boxed. The skid and main sections of the link mounts are 1/4" steel. The lower link mounts were designed with 1.25" x 1" rod ends with 1" x 3/4" high misalignment spacers. The mounting width of the lower link boxes are 2.63 wide" With that said Johnny Joints with the same 2.63" mounting width can be used but may require weld washers to change the bolt hole size which is 3/4".
The upper link mounts were designed for 7/8" x 3/4" rod ends with 3/4" x 5/8" high misalignment spacers. The uppers will not work with Johnny Joints. We chose the 7/8" rod ends to keep the mounts tight to the frame rails up front. By doing so it allows for a many different engine types.
Check it out. Be sure to let me know if you have any questions.
Jeep YJ Four LInk Suspension Kit and Skid Plate Motobilt, Inc.
Vendor
Discussion Starter #3
Vendor
Discussion Starter #6
BLACK FRIDAY DISCOUNT CODE: VALID THROUGH MONDAY.
Enter code: Black-BMF and save 15% on Motobilt brand parts. Packaged deal items are excluded from the sale.
Vendor
Discussion Starter #7
Installed a kit on a customer's YJ frame yesterday. I converted the front for use with a 3 link and mechanical steering. This was done by simply removing one of the upper front link boxes.
Vendor
Discussion Starter #8
There will be a couple happy people at Christmas. Working on a couple Christmas orders for the 4 link kit. Thanks for the business. LOL One wife called and said she wanted the 4 link thingy for a Jeep her husband was talking about. I told her we had a 4 link thingy in stock. Haha... good times.
Vendor
Discussion Starter #11
We have one setup in stock. We can get it welded out and one the way this week. Let me know. We got slammed with orders on this part over the holidays. Thanks for the business. We are looking forward to seeing some more build threads.
-Dan
Vendor
Discussion Starter #14
Thanks for the orders over the weekend on this kit. Be sure to call me at the shop if you have any questions about this or any other Motobilt product.
-Dan
Vendor
Discussion Starter #15
Vendor
Discussion Starter #16
Building out a few more of these now. John Simpson yours is just about ready to go. Thanks for the business everyone
Dan
Vendor
Discussion Starter #17
Who wants one? Give me a call at the shop. Lets make it happen. We are moving Motobilt to a new shop. I feel like making some deals. Thanks for the business everyone. Let me know if I can help with anything.
Dan
Vendor
Discussion Starter #18
We are putting another batch run together tomorrow. If you are ready to order please call me at the shop. We are currently finishing the move to a new location and have not been spending a lot of time online. We should be back to normal by the end of the week.
Dan
Vendor
Discussion Starter #20
We have been steadily shipping these out the doors the past few weeks. We have another two getting ready to go now. Thanks for the business everyone. Much appreciated.
1 - 20 of 139 Posts
