1 - 8 of 8 Posts
WHOOHOOO!!!!!!
here are a couple pics of the jeep with tires actually on it.
here is the front axle... almost done
i have 1 ft of ground clearance at the bottom of the diff and 25" at the bottom of the hoop of the bumper and 29" at the bottom of the regular part of the bumper.
oh and 31" at the bottom of the rocker. im pretty happy.
Hey DP,
I bet you a six pack that it will not be done by the 10th. You will never get it done. <IMG SRC="smilies/thefinger.gif" border="0">
Nothing motivates him more them beer. BTW, I am serious and will pay you up in Paragon if you make it you <IMG SRC="smilies/rainbow.gif" border="0"> .
hmmm that sounds a lil bit like ROB!!!
JOHN
ok the rear axle is an 86 grand waggy dana 44. Completly torn down and rebuilt from the ground up. re brackets, welded thing with the pinoin where i wanted it. <IMG SRC="smilies/biggrin.gif" border="0"> 4.56's full detriot, had a buddy powdercoat the diff cover, challenger performance diff guards, fabbed brake lines, all new brake parts (the 20 year old ones were rusty hehe) 6 on 5.5 bolt pattern. big drums compared to stock. 1.25" turned aluminium wheel adapters.
front
82 grand waggy dana 44. completly torn down like the rear. re brackets, welded the lower control arms wider then stock for slightly more stablity with the a arm. New calipers, new outer shafts, all new hardware ie ball joints, tie rod ends tie rod etc, but all stock compoenents. knuckle over steering(stock waggy setup) 1"+ solid tie rod(stock) warn premium manual hubs 4.56's detriot true track (didnt want a full locker at the moment) oh and the challenger performance diff guard. I think thats it.
basicly i stuck with the waggy setup because its made to deal with a vehicle several thousand pounds heavyer then a TJ. I bleed the brakes last night and drove it outa the garage and MAN the brakes are NICE!!!! ive NEVER not even STOCK had brakes like this.
ive got my wheelbase at 96" at the moment but the rear is not where i want it so im hoping to stretch it a lil bit more.
hope that helped.
1 - 8 of 8 Posts
