Jimmy’s 4-Seat Turn-key Buggy for Sale
Asking $38,000
Sulphur, LA
Kids are both off to college so it is time to sell. Buggy is in like new condition with probably less than a dozen trips on it. No damage to tubes or body panels and only a few minor scratches to belly pan.
Information from build:
Full powder coat 2-3-4 chassis 1.5 x.120 dom w/ 1-piece laser cut belly, engine cross over tube, seat bar, oil pan skid, and all fill bars for shocks and fuel tank.
4-link suspension with 1.5 x .25 dom uppers and QA1 3/4 x 5/8 joints, 1 3/4 x .375 dom lowers and QA1 7/8 x 3/4 joints, and stainless washers with grade 8 nuts and bolts.
108” wheel base, rear sway bar, Radflo coil over shocks and air bumps, and limit straps.
Custom painted Escalade clip mounted w/ poly hood pin kit. All aluminum floor, firewall, roof, doors, and kickers.
GM 6.0 w/ LS1 intake and Delphi Marine ECM.
Rebuilt THM-350 transmission w/hd parts, full manual Transgo Fwd shift kit, compression braking, Stak adapter, and OEM stall converter.
Stak 2-speed transfer case with 3.8:1 gears.
Front axle is a GM Dana 60 with OEM c's, 5.13 gears, Yukon c-molly shafts and solid joints, Solid keyed steering arms, Solid keyed knuckles, Solid HD diff cover, 8-lug Solid conversion wheel hubs, Jimmy’s drive flanges, and 1350 yoke. King pin kits, spindles, bearings, seals, gears, hubs, and disc brakes were all new at time of build.
Rear axle is a 14T w/ 5.13 gears, a Detroit locker, and Solid HD diff cover. Gears, all bearings and seals, and disc brake conversion were new at time of build.
KMC bead locks with BFG Red-label Krawlers.
PSC Hydraulic Steering Pump, Orbital, and cylinder.
Two lever left and right cutting brakes.
Fuel tray with 8 gallon RCI fuel tank and shut-off valves.
Parker hoses with push lock fittings.
Twisted Stitch seats with two position adjustable driver’s seat, DJ harnesses, and window nets.
Headlights, taillights, and rock lights.
Ice chest / tool tray.
Warn M6000 winch with rope and aluminum fair lead – never had to use, still brand new.
PM or call/text 337-764-4766 with any questions.
Asking $38,000
Sulphur, LA
