Jimmys 4x4 RW1
Jimmys production # 170506
AR500 belly pan and skid plate
Wheelbase
109 with room to grow
Width
65” front wheel mounting surface
64” rear wheel mounting surface
Passenger drop
Supercharged 3800
Came out of 2002 Regal with 78,000 miles
Atlas 3.8
AA production # 3758
Atlas support ring
700R4 wheel built
Hughes performance serial # 25275 invoice # 48279
Front Tera Flex CRD High pinion Dana 60 (65” front wheel mounting surface)
Newest ARB 167
538 Yukon gears
Yukon chromoly 35 spline shafts cleared for 50 degrees of steering
Comes with spare
Ballpoint eliminator
Rear Tera Flex CRD High pinion Dana 60 (64” rear wheel mounting surface)
Newest ARB 167
538 Yukon gears
Chromoly 35 spline shafts
Comes with spare
Solid Axle 35 spline Drive Flanges on each corner with upgraded spiral rings +
SAI-SA35FK
Rear Drive line 188 wall with 1410 joints
Front Drive line (2 piece) with carrier bearing 188 wall with 1350 joints
PCS full hydraulic ram with aluminum drag links
PCS TC High flow power steering pump
Fuel and transmission lines are all rebuildable -6
Hughes Power steering reservoir with filter
Aluminum links with 7/8 Heim joints with 3/4 grade 8 bolts
15 gallon gas tank
Pyrotect fuel cell with removable lid and bladder with high grade fuel foam
Rear mounted 27x15 aluminum radiator with two 12” spal fans
Front mounted CBR transmission cooler
CBR2827
Front mounted Full hydraulic power steering cooler
Corbeau Baja XP Fixed Back Suspension Seat
Driver’s seat heater
Crow padded 5-point harnesses
Oh goodness passenger grab handle
Odyssey battery (PC680)
Winters shifter
Rear cutting brakes
PCI race Radio with antenna
Autometer electric gauges
Water temp gauge
Oil Pressure gauge
Transmission gauge
2 fire extinguishers
Rearview mirror
Removable steering wheel
14” Fox 2.0 coilovers
Rear light sway bar
Fast Ramsey EP9.0 winch with synthetic rope
Warn rear suck down winch
39 BFG reds (might come with 2 sets if timing is right)
Raceline beadlock wheels 6 on 5.5 with spare rings with 4.5 backspace
Willwood brakes and Branik Motorsports hats and rotors
Dodge (M390258) 1 ton master cylinder
7” dual diagram brake booster
Hood is removable with deutz fasteners
Floorboards and body panels are removable with companioned 1/4 20 trick tabs
Spare unused panels
