1 - 12 of 12 Posts
JIMMY'S 4X4 chasis. St george UT. 45k OBO
Call or text 8I7-372-5I3 nine
49" at shoulder bars
41" roof width
85.5" outside tire to outside tire
74" roof height
21" belly height
113" wheelbase
LQ4 with cam, 317 heads, tune and 2 qt accumulater
Th400
Atlas 4.3
2 sets of drivelines
Front axle is a high pinion dana 60 with reid knuckles, RCV 300M shafts, artec highsteer, PSC ram, 5.38s with ARB.
Rear axle is a shaved 14 bolt, 5.38 gears, ARB full truss and rear spine, pinion guard
Bilstein coil overs and bypasses tuned by bilstein at KOH.
Bilstein bumps all 4 corners
Warn winch with synthetic line
Jaz fuel cell with foam and roll over valve
All aluminum link arms.
Rear tire rack and rear cooler rack.
Rear cutting brakes
PrP seats and 5 point belts
And most importantly for old guys like me DOORS! They can be pinned for competition legality.
Discussion Starter #7 (Edited)
Flatbed info...
2000 F-750
CAT 3126
Eaton 6306 6 speed manual
26' flatbed
Air brakes
22.5 Alcoa wheels
Air conditioning
And for you CA peeps. It has a mobiclean 26a DPF installed as its a former CA truck.
Only listed these because the RONA has me out of work for the foreseeable future....
Discussion Starter #10
specs and price on the 4 seater please , thanks :D
Asking 25k. OBO
S&N FAB Venom 4 Seat Chassis
MOTOR
Ford 5.0
Bored .30 Over
E-303 Camshaft
TRANS
Ford C4
Full Manual
2100RPM Converter
T-CASE
Atlas 4.3:1
1350 Yokes
32Spl Outputs
RH Drop
AXLES
Dana 60s Front & Rear
Detroit Lockers Front & Rear
5.38 Gears
Chromoly shafts with yukon superjoints
WHEELS
Spyderlock beadlocks
40" Nitto stickys at 90%
MISC STUFF
• PSC Dual Ended Ram Full Hydro*
• Radflo Coilovers 12” front & 14” rear
• All Aluminum Links
• Art Carr Shifter
• warn rear winch
• superwinch front Winch
• 30” Light Bar
• PRP Super-Comp Seats
• Corbeau Seat Belts
• Gold With metal flake Powder coated Chassis
• Black Powder-coated Panels with Gold metal flake
• 05 Cadillac Escalade Hood & Grill
• Aluminum full roof panel
• Marabou "Expensive" wood Dash & Center Console
• Autometer Gauges
• Aluminum floor panels are Line-Xed so no slipping when trying to get in and out
• Odyssey battery
• Fox air bumps all 4 corners
Discussion Starter #12
Had a question as to what has been done to the 2 seat buggy in the 2 years i have owned it.
All of the following changes/upgrades have been done since i bought it.
New Atlas 4.3. It had a 3.0 which was not low enough for what we do.
Added rear cutting brakes
New Front and rear ARB lockers
New ring and pinions, bearings seals,
RCV 300m front shafts
Complete new PSC steering system. Pump, ram, orbital and lines and axle mounting.
New PRP seatbelts
Maxxis 42s
Arb compressor
Artec high steer double sheer arms
Odyssey battery
All fluids and filters twice
1 - 12 of 12 Posts
