1 - 6 of 6 Posts
Differential is a GM 8.5" 10-bolt. I would like some advice on the pinion depth.
The first pictures are with the factory .035" pinion spacer, with .008" backlash.
Hood Automotive tire Automotive lighting Automotive design Coil spring
Automotive tire Gas Motor vehicle Automotive fuel system Automotive wheel system
Next, I tried a .039" shim stack, and here is how it looks at .009"
Automotive tire Automotive lighting Hood Motor vehicle Tread
Automotive tire Motor vehicle Hood Tread Coil spring
Last, here is the same .039" shim stack at .006" backlash:
Hood Automotive tire Motor vehicle Automotive lighting Tread
Automotive tire Coil spring Tread Gas Shock absorber
Which looks best? Or am I completely off-base?
Here you go, my fav:
Thanks, I really appreciated the video, but contact patterns I'm getting don't seem to match what that guy was showing in the video; probably the cut of the gears I'm using (5-cut).
I consulted with some guys at work today, and they think the last pattern looks best (.006" backlash, and .039" shim.), and I agree.
I hear ya, he explains situations with irregular patterns as well. The main point is to get everything as centered on the teeth as possible and hit your backlash. Outside of buying new gears there is nothing else you can do except send it lol
1 - 6 of 6 Posts
