1 - 20 of 865 Posts
Well, I'm bored and I figured it's about time I posted this up here.
Yeah, it's just another college built rig, except not exactly a "budget" build :smokin:
Never done anything REMOTELY close this amount of fab, so i've got a little bit of a learning curve to tackle :laughing:
Been slowly collecting parts for a while and due to shoulder surgery october before last at the ripe old age of 21 :rolleyes: progress started later than I wanted. Being a full time ME student at Colorado State University and working as a Tire Tech at Discount Tire takes a bit of time out of my week as well.
The rig was pristeen when I got it with ~65k on the odometer, but that didn't last long :D
Couple pics before the teardown:
Clean driveway shot right after it was done (highschool)
Carnage Canyon in Boulder
Indy in Penrose
Discussion Starter · #2 ·
Yeah, I abused it to say the least...
It looked like this after a flop on Upper Helldorado...and the body damage only continued after that day:
So now to the present...keeping up with freinds buggys and other more equipped rigs has become quite the venture.
Specs on the build:
-HP60 from a '79 Ford F350
-14BFF from a mid '70's Chebby
-16" FOA Coilovers on all 4 Corners
-42" Iroks on 17" Black Steelies (weld on locks in the future)
-Double Ended Full Hydro
-Triangulated Four Link Rear
-Triangulated Four Link or 3 Link with Panhard Front
The list goes on...
Well last summer before last a buddy and I drove to nebraska to pick this up:
Whats that attatched to the front end!?
Got it all cleaned up and primed, and bottom of cover shaved to match D60:
After a bit of work and a LOT of money...voila!
Specs:
-5.38's, Detroit, RockCrusher Cover, Dedenbear Knuckles, PSC High Steer Arms, H.A.D. Forged 1350 Yoke, Alloy USA inners/outers, Warn 35 Spline Hubs...basically the only things stock left on the axle are the housing, caliper brackets, and hubs...everything else is new. :smokin:
As well, a box containing some more toys arrived
P.O.S. double ended Ful lHydro Setup :smokin:
Well this is what it looked like after a day with the sawzall...still more to be cut off:
Got these winter before last...42x14R17 Iroks with about 70% Tread
Well next was getting the frame rails sleeved...what a B*TCH.
Drilled out all the spot welds on the leafs hangers and the upper control arm mounts
Then got the rails all flap disc'd and cleaned up
Had to cut some lips off the inner part of the frame rails, weld them together and clean them up...that was oh SO fun
Once was that was all said and done...it was time to get material for sleeving. What I ended up with was...
4" x 6" x 1/4" box...
Yeah a little heavier and thicker than I would have liked to have gone, but it was cheap, and I will have a lot mounted to it, so the beef will help. Well, got to work on it cutting it in half...
Several HF grinders lost the good fight cutting that sucker in half
Driver's side fitted up
Everything will be tacked up for the time being, then I'll drop everything and weld it up fully...
Now it was time to start on my Tranny crossmember :evil:
I've got 300ft. of 1.75" x .120" HREW to work with on this so most things will be made out of that. I won't lie, getting the logistics worked out on this thing was a nightmare, but I got it to work out.
Started with some tube, and this little sucker I whipped out
I don't have a lot of pictures of when I made this since I kept forgetting my camera, but I'll make sure to when I take it back off since much of the work can't be seen...
Crossmember:
Where bushing attaches to to bolt onto AW4 adapter:
The hex bolts on the bottom allow for the panels to be removed in order for access to the bushing bolt and adapter bolts.
Yeah I know many will say I should have started over with a clean body, etc. etc. but that wasn't really an option. I needed the VIN so I could drive it on the street, and I can't afford I new rig. I don't want to build anything else either as there are more TJ's, CJ's, etc. on one tons than one can shake a stick at, I wanted something a little more original.
Back onto the building...
Did some more trimming and looked at tire placement
Now onto the 4-link. I'll be going with a double-tri setup with 2.25" x .375" DOM lowers and 1.5" x .25" DOM uppers. I'll have a mix of Ballistic and Currie Joints in the 1.25" flavor on the lowers, and 7/8" ballistic uppers. Here's the numbers i will be running on the 4-link, they took me a while to get but AS goes up during bump, and drops during droop.
My workstation and mock setup. I'm using pieces of PVC for mock up arms and to make sure things work.
Started working on the frame side setup for the links. This was interesting to tackle to say the least. Started with one tube, which I then notched to move it as far back as possible to allow driveshaft clearance....and then cut away a bit more floor :lol:
Then I took some 3 x 3 x 3/16 and made the brackets.
Added some bracing
It then occured to me one hit to where the notch in the cross tube, and i'll have a good and bent crossmember. So I added this...
I think that should hold up pretty well:thumbsup:
Might be slight overkill but oh fawkin well...
Starting on the truss for the 14 bolt...
My first real attempt at bending tube. I will say this, bending tube is hard to repeat when you've never done it before, and notching is pain in the A$$ and can be VERY time consuming. This shouldn't be as much of a problem as I get more experienced with it.
Discussion Starter · #10 ·
Lower link mounts top part:
Now to my subframe rails...theres a LOT of work into these. I'll try and let pics speak for themselves. The smaller holes are the 5/8" bolt through holes for the tranny crossmember and rear four link crossmember. The bigger holes will be welded, they are all 1.5" via holesaw.
Discussion Starter · #12 ·
Getting the bottom plating (1/8") started
More finished product...
Installed...
Starting on the upper link mounts....got the brackets all sketched and ready to be cut out...
Overall i'm pretty happy with how its turning out. I'm pretty picky with things so when they're not perfect it bothers me, but i'm accepting things not being perfectly symmetrical in areas as its hard to make them perfect with limited resources :thumbsup: Welds aren't as great as i would like them to be, but I just need to work on consistency a little more, haven't welded this much in a while.
looks freakin sweet man. can't wait to see more. i am also in the middle of a build with 42s. only got 18 months in to it now.
Discussion Starter · #18 ·
First off I finished up some work on the rear 4-link, so other than getting the links 100% welded the rear 4-link is DOOOONE!
"Boxed" in the upper mounts:
Well I had started work on sleeving the rest of the "frame," which to say has/was a nightmare is an understatement. I can't count the number of times I had to play cardboard mock up to get things right...and I've still got some fixing to do. I'll kinda let the pics speak for themselves as usual.
Decided to gain a little clearance on the "frame," as it would help my lower link not too hit it:
Driver's side getting done:
This is what took for-fukking-ever, well at least part of it. Its a two peice sleeve for the frame rails, with the out edge being bent in my press to keep it down to two peices. I made these out of 3/16", not 1/4" like the rest of my sleeving.
Discussion Starter · #19 ·
Installed and connected to the frame sleeves, but not yet fully welded on.
"Finished" products...though they're not truly finished since I had to modify them more since my lower link are hitting the recessed portion as seen in a couple pics. Overall i'm satisfied with them, but not 100% happy how they turned out.
Discussion Starter · #20 · (Edited)
Oops...
And FINALLY...
Yeah...the tubing has some rust on it. Thats what happens when its been tarped up the best possible but sitting outside since the summer. FINALLY got it from my friends house I started working on the Jeep at to my place...never would have thought it that hard to get the tube moved a whole mile :laughing:
1 - 20 of 865 Posts
