Just spent a bunch of time swapping out an internal slave for an external slave set up on an AX-15/ 4.0 in an XJ.
Only one problem- Now that I have the thing back together the clutch won't engage! Bled the hydraulics but no shifting with the
engine running. Pumping the pedal doesn't help. Won't engage at all.
I'm sure I put the clutch pack in flywheel side to flywheel so some questions come to mind: What else can go bad?
Is it possible to put the fork in a bind when mating the engine and tranny?
Can you test the clutch manually by working the fork through the slave hole? How hard and far would you have to press the fork in?
I'm also not sure if I bled the slave right. Haynes says to compress the slave with clamp and bleed with pedal. That what I did. Is
there more to this? Also- does the bleed screw face up or down when installed on the bellhousing.
Anyone had the joy of dealing with these symptoms before? I could sure use some guidance about now. I'd hate to have to tow this
somewhere and bend over for another clutch job. <IMG SRC="smilies/pissed.gif" border="0">
Thanks
Johann
Thanks
Johann
