21 - 37 of 37 Posts
Metal Magic
Discussion Starter · #21 ·
I also installed the Yukon super joints and the front axle shafts.
3115699
3115700
Metal Magic
Discussion Starter · #22 ·
When I bought the axles second hand they already had chromoly shafts and super joints but they were not installed. I found out that they ordered ford chromoly shafts and super joints and would not work in this axle. It’s funny how god works sometimes because I opened the rear diff cover and it did have 5:13 gears with Detroit Lockers. But from the picture you can tell it was setup incorrectly.
3115701
Metal Magic
Discussion Starter · #23 ·
So I figured out that the 4149 shafts I got with my axle were for actually for a Ford Axle. So I ordered the correct shafts with super joints.
I also started putting all the parts I drew in Solidworks into a chassis design.
3115702
3115703
3115704
Metal Magic
Discussion Starter · #24 ·
I also started cutting out my sub frame assembly. I chose to make my sub frame in this way because I didn’t want to use rectangle tube and have to worry about drilling through both frames to make it even etc. here are a few pictures from me assembling that. It’s a tab and slot design so it can only be assembled one way. Also a picture of the pallet of parts I have for this project. The skid plate is a 3 piece design and can be removed. I also choose to make my shock towers adjustable up or down 3 inches.
3115705
3115706
3115707
3115708
3115709
3115710
3115711
Metal Magic
Discussion Starter · #25 ·
Haven’t gotten all my pictures off my old phone but here is a picture of the chassis with my wife testing out seat position. It’s coming along very well so far. I made it the chassis large enough for me because I’m 6’3” and I didn’t want to be cramped.
3115712
Metal Magic
Discussion Starter · #26 ·
I am not sure how well the adjustable shock mount will work but once I get everything setup the way I want I may weld them in. Haven’t made a decision yet. Here are a couple pictures of cardboard between the mounts and the mounts that weld to the chassis.
3115713
3115714
Metal Magic
Discussion Starter · #27 ·
New piece of equipment for the new shop. Don’t have power yet so I can’t even plug it in and play with it. This is as bad as being a kid at Christmas.
3115715
3115716
Metal Magic
Discussion Starter · #28 ·
So I've finally gotten moved into my new building. All equipment was moved without much problems. This week I have been able to get some work done on the buggy. It is sitting on all for with suspension in place. I am at 19" off the group with a 113 wheel base. I made some tie rods for the hydro steering but they are 1 inch to short. I copied the extensions that came with the ram. I have some new tie rods made that I'll throw on tomorrow. In the picture the bottom of the tire is 45" from the ground.
Some new tube ends. Thinking about offering these if anyone is interest along with custom length tie rod extensions.
Metal Magic
Discussion Starter · #29 ·
Some of what I’m working on. These tie rod extensions were for a Can-Am defenders but its how I did mine also. I put 7075 inside my lower links after I turned them down a tad to get them to fit ha. That was a bitch.
3115717
3115718
3115719
3115720
3115721
Metal Magic
Discussion Starter · #30 ·
I made some new tie rods to replace the other ends I made. Wanted a bit of “flare” haha
before and after
3115722
3115723
  • Like
Reactions: CJ_Tom
Metal Magic
Discussion Starter · #32 ·
I guess I forgot to post pictures on my gauges.
3115759
3115760
3115761
3115762
All I have to say is, WOW. I am jealous and envious of your CAD and fabrication skills. Being an old fart, I would love to learn CAD, but it is not as easy to do as it was when I was younger. Great project! Let us know how she works on the trails, with photos.
Metal Magic
Discussion Starter · #34 ·
So this is how today has gone for me. I cut off the rear head bar because it was actually not the way I wanted it in the beginning but my inner child wanted to see progress when I got to that part and I put it in anyway. It was supposed to stick out in the rear a lot more than it was and I decided to see if it would grow on me. It did not. So I added the new bar and then got frustrated because I let my arrogance get the better of me and did t take my time to get my notch just right. So I moved to getting the radiator mount built and installed. I let Ashley weld that up for me while I was doing other things. Then I was by myself so holding the radiator, the bracket and trying to weld it in got me even more frustrated but I got it tacked in. I’ve gone multiple ways on how layed over I should have this radiator and I think I’ve settled on this. Stepping back I like the look, I’ll see how I feel about it tomorrow and either fix the notch and weld it in or remake it.
3115888
3115889
3115890
3115891
Metal Magic
Discussion Starter · #35 ·
Never too old to learn. I will say this though, when I spent $8K it was a HUGH, HUGH motivator to learn it!!
Thank you btw.
Metal Magic
Discussion Starter · #37 ·
Well I working on getting my aluminum overflow tank finished up. I haven’t had much time for anything else honestly. Made everything in house.
3115976
3115977
3115978
21 - 37 of 37 Posts
