1 - 20 of 38 Posts
Here at Performance Cryogenics/Kickassoffroad we build parts mostly for wholesale customers but do make parts for retail customers also. Our focus is in CNC lathe turned parts such as tube adaptors, hi-misalignments, spring eye sleeves, weld washers, weld-in nuts and such. We also do bolt-on drive flanges for rear axles, custom axles, resplining, KOH winning swaybars, and custom doubler shafts. One turning center is set up for 1 3/8" bar stock with a bar feeder and the other can do up to 3 1/4 bar. So if you are a shop that wants to have their own parts made for them then give me a call and we can go over some pricing structure.
Dean
Discussion Starter #4
They are $125 for the pr. Not sue on the shipping though as we are on opposite ends of the states from each other.
Dean
Discussion Starter #7
I guess if I am going to put up an add of some sort I guess I should check it from time to time.
Yes this is no problem to do. Easier that a 205 since that is the case, not just the aluminum snout. $100
LOL, I guess that was a reply to my D300 bearing ret. machining.....cool, I will be in contact with you soon. Let me tie up some loose ends and get that D300 apart. thanks! John
Discussion Starter #11
They are $275 to make 1. I have all the spec's we would need. On the 25 spline how much of that are you using?
The rear 60 you shaved and built the shafts for has been under my rig for years. I threw it in within a couple of months after picking it back up from you.
Front 60 is going in as I type this.
Axleshaft Resplining
I have 2 sets of 79 Ford Dana 60 Rear Axleshafts, can you PM me a price to shorten them from 34 1/2" to 33 1/4"?
Discussion Starter #20
Rear shafts neck down so they cant be resplined most of the time. If they can they are $125pr
1 - 20 of 38 Posts
