I purchased a set of low mile used Krawler's almost 4 years ago, I put them on the truck about 2 years ago, and it's sat in my garage unmoved (Except for rolling it out into the driveway to clean the garage, then right back into the garage)...
I finally got a fire lit under my ass to get the truck back rolling and into drivable condition last week. I filled up the tires (Each one had about 10PSI in it and I took it for a spin around the neighborhood. Granted it doesn't have shocks on it, but there was a horrible hop and at low speeds, and high speeds it was a pretty good Vibe. I stuck my head out of the window, and I could see low spots in the tire as it's rolling. I jacked up the rear end it appears as though all 4 tires have flat spots in them. Now I never drove on these tires before tonight, so I don't know if they were this way to begin with...
If I drive on them and heat them up will the flat spots go away? am I screwed and need a new set of tires... :crybaby2: One of the wheels is leaking air from what looks like rim screw holes (But there are no holes in the tires) so I'm going to have the tires removed from the wheels, and weld up the holes. and get them rebalanced.
Advise?
Advise?
