1 - 7 of 7 Posts
Does anyone make a replacement fender flare for the Defender series that would allow say a 37" tire with minimal lift?
Europe maybe? Iceland?
given the simplicity of the fenders, seems like just about any kind of "extend-a-fender" type setup would work. have you looked at placees like bushwhacker, etc? what about just usingn some wide rubber. do a search in this forum for lwg's DIY fender-flare project. used some kind of jc whitney kit IIRC.
I belive the Icelanders use som form of Jeep flares.
The problem when widening a Defender is that you loose 3" each side when you remove the eyebrows, so you need really wide flares to make any difference.
Try extending the existing ones by adding a few inches of aluminium or black plastic between the fenders and eyebrows. It has been done, and seems to work fine. Cheap, too.
1 - 7 of 7 Posts
