61 - 80 of 105 Posts
Discussion Starter #61
Changed all the bearings and seals
Cleaned the brake shields for painting
Welded a nut to the damaged oilplug so it will be easier to remove
Found one more old picture :)
Discussion Starter #62
Got a little more done, expanded the home-built window frame I had, also fixed to the corners so they look a bit better
Although welded to a plattgärn in the middle to receive the split window look :)
works fine
The brackets and homemade thumbscrews
Think it will look totally okay with some color :) Then it's not the appearance that is important in the woods :grinpimp:
I'd like to see the back/inside of the frame.
Skip
Discussion Starter #64
Skip
The window frame? : P
Here's a pic
I have cut away a little more of Felt frame, I have also narrowed the tank protection so it fits between frame so the gas tank comes up a bit
The rear axle is almost done : )
Welded some mounts for the headlights
Built my own swedish interpretation of the Willy's blackout lights, I'm happy with it :D
Also built radiator mounts, mounts for the grill in the frame. Now it starts to resemble the jeep again :)
Bonus picture that I threw together in Photoshop, "Put the jeep in the woods and threw a little color on it" So you get the feeling of how it should be
Your windshield frame looks great. In case I missed it, will you have to get the glass custom cut?
Skip
Discussion Starter #66
Skip
The glass will be custom cut. I will probebly start with lexan.
Yesterday I made a bracket for the expansion tank in stainless
:D
Discussion Starter #67
Built protection/sidestep yesterday
Looks good :D
Discussion Starter #70
I like it, I need do something for my step area as well.
Functional and looks good. According to me at least :D
Nice work. What kind of Corvette? I have a 2004 6spd I bought new. Lemans blue.
Thanks!
Nice! I also have a 6spd C5 a 2000 millennium yellow targa.
Here's a pic from last weeks trackday, Haven't had the time to paint the new hood I built :D
Today I built seat brackets
Only test
Cut a little in the front "bumper"
Test mounted, also found a couple more lights from one of my fathers old army tractors
Discussion Starter #71
Poor mans lathe :D
Made the end pieces from tig wire
Looks Ok :grinpimp:
Built a bracket for the shifter. Just have to weld it and the seat brackets to the tub now
Discussion Starter #72 (Edited)
Rolls on slowly but surely with the build, got a little rust primer on it today
I'm also building levers for the transferbox
The control arms are ready
Mounted blackout lighting and some more small things
Discussion Starter #73
Not much have happened this winter. The house have taken a lot of time and I have also started a track car build.
Got some more rust primer on it in the autumn.
I need to clean om the last of the rust befor priming the bed
I'm very pleased with the windowframe :)
Discussion Starter #74
The spring is here and some sun with it :)
So got some of the last parts out for some grinding and cleaning before priming.
So much old paint and plaster
Just some primer needed now.
Discussion Starter #75
Today i have grinded away some more old paint :)
Almost done
Just some primer on these parts, the hood and grill then I can start with the olive drab :D
Discussion Starter #76
Got some stuff from Classic Jeep Parts this friday. Olivedrab paint and a hood hinge.
The new hinge in place :)
Got some rust primer on the last parts.
Now I'm looking forward to seeing it become green :D
Discussion Starter #77
Dragged the jeep out in the sun last week
Project cars as far as the eye can reach :D
Welded some holes that some one hade made earlyer with a blunt axe or something
One hole filled in, the other I'm using for a intake pipe, so I can have the airfilter under the dashboard.
Some zinkspray on it before the rustprimer
Discussion Starter #78
The filter under the dashboard :)
I have also built a exhaust system
Discussion Starter #79 (Edited)
Welded the front bar to the frame
Som more welding done :)
Is anyone reading this? :) Or at least looking at the pictures?
Master Tinkerer
Of course we are reading this! .....I'm in Italy right and could show up on your door step anytime so be careful......
Never know someone might be in Sweden next week and want to see your stuff!
Also your doing a nice job!
