81 - 100 of 105 Posts
Master Tinkerer
also if the rest of the cars in your driveway are any indication of what happens in Sweden comes from other places then I'm visiting for sure!!!!!
Discussion Starter #84
Thanks for the comments!! it's fun to know that people are looking at what I'm doing :)
Got my new front indicators
I have also modifyed my old auxiliary lamps for better light
Should work better than the old lightbulb
Got som more stuff in the mail, our dog wonderd what it was
Discussion Starter #85
Never seen someone so intrested in a mirror :p
Had to modify the rear shock mounts so the fitted under the tub and did't hit the tires
What size is the mirror head? Mine was missing and thinking of going back to stock. Where did this one come from please?
Discussion Starter #90
Glad i could help :)
Test fitting parts, mirror, headlights, indicators and hood latches fitted
Building the sidestep on the passeger side, I also shortened the exhaust so the exhaust tip won't hit the tire.
Now I'm waiting fore more parts :)
Nice Work
I have the same type of sidestep/rockslider and they works really well.
How tall is your car under the rockslide?
Discussion Starter #92
Nice Work
Thank you :)
It's about 90cm (35 inchs) from the ground to the underside of the sidestep.
Discussion Starter #93 (Edited)
Got my new windshield seal today, got to modify it a bit to fit my homemade windowframe but I think it will work :)
Discussion Starter #95
Yesterday I removed the old holder
So I could fit my new grips, they sits a little higer then the original due to my fuel filler hole
Also fitted a rear reflex and taillight
Discussion Starter #96
Tear down :D
Needed a new backbeam
The old one is gone
Made it look a little better
Discussion Starter #97 (Edited)
Cleaned and sandblasted the shackle mounts :cookie:
Welded in place
Removed som leafs from the spring assembley
The reason for that is that my willys is going to be lighter then the Felt
The engine is removed so I could weld the engine mounts
Discussion Starter #98
Got som primer on the underside
And a layer of paint :)
Discussion Starter #99
The house takes up all the time, so the jeep build is a little slow right now.
At least I have got som colour on it =)
Discussion Starter #100
The exhaust system got a little heat resistant color too :)
Mounting the sealing strip on the windowframe
Looks a little nicer with color on: D
