I have found some posts on early 22-REs into early trucks and swaps from 22r to 22re, but I am putting an 89 or later (don't know for sure but it's a later engine) engine in an 82 pickup. I have two big problems one is the alternator connection. The truck's wiring and the new alternator have the same number of wires and seem to be about the same gauge but I don't know which wires go where. Second is getting power to the ECU can I just supply power to the B terminal and be good to go? Also the harness that is suppose to go into the cab has two connectors that I know nothing about. All the information that I have found on here has been for the earlier 22res and the wiring coloring is different for the later engines. If anyone has any info it would be much appreciated.
-ben
-ben
