1 - 6 of 6 Posts
pretty cool again. the only issue i have with this design and your id radius attachment is having to do trial and error to get your radius correct. i can't think of an uncomplicated way to fix that though.
Discussion Starter #4
First piece.(it is not as rough as it looks)
I need to pick up some finer grit emory paper and I would also like to switch to a carbide insert tool to try and achieve a smoother cut.
Would anyone be able to recommend a particular style or type? One of the toolmakers suggested that a triangular insert with a radius of .030" would work well for this.
Video: Making the ball for the handle.
http://www.youtube.com/watch?v=OCbA0mNMNzs
Discussion Starter #5
Thank you.
So far I have been able to get things pretty close by just using a scale to set the distance of the bit. I'm sure with more practice I'll get better at it.
Both cutters.
a carbide insert with a radius will definatly leave a smoother finish. grinding a radius in your hss cutter would also help.
1 - 6 of 6 Posts
