My C-6 is leaking like crazy from what appears to be the front seal. The jeep is sitting at a slight incline (pointing up) and it is dripping about 1/8 of a quart per day from the front bottom of the tranny.
The tranny was recently rebuilt and has always been run dry. It used to only leak slightly when pointed downhill but now it leaks when on even ground.
I also just recently installed fuel injection. Do you think that would cause any difference in manifold pressure and consequently caue the seal to blow?!?! I'm grasping at straws here........I REALLY do not want to pull the tranny again.
