im wrapping up my build (see project homewrecker) and have gotten to the wiring portion. I am running into some issues and need assistance. I have the headlights working (both high and low beam), brake lights, and side marker lights (on the front fenders). I am having some issues getting the rear marker lights (which I am not too concerned about at this point) as well as the turn signals. I need someone to put the turn signal wiring into simple terms. I have power to and from the switch at the column, but i get confused from there. I believe my flasher is trash (someone just bent a standard flasher to fit the plug for the FJ40 flasher). Once i swap that out do i need to have a bulb on the wire to actually get the flasher to work? I am going to all LED lights so i am going to try to either wire in a bulb somewhere along the way, or get whatever i need to make it work right.
i am using this wiring diagram and so far it has been very accurate. http://www.ih8mud.com/tech/72fj40-wire/71fj40_wire.gif
could use any tips that you guys have run across.
