1 - 20 of 106 Posts
Vendor
Click here to order!!​
NEW PRODUCTS!!
The Rigid Industries’ Radiance LED Light Bar is feature-packed, with a black exposed printed circuit board, optimized forward projecting Broad Spot optics which combine the attributes of a spot and flood beam pattern.The coolest feature is the back-lighting available in white, amber, red, blue and green.​
Vendor
Discussion Starter #2 (Edited)
4-INCH LED ROUND LIGHTS
Get the classic round look with modern LED technology in one perfect package! Featuring two all-weather, round LED lights capable of producing a total of 54 Watts and 4320 Lumens, this setup makes it simple to see farther when it counts. With a simple stud-mount design and durable Die Cast Aluminum housing, these lights can take a beating.
Vendor
50in Cree LED Light Bar - (Dual Row | X5 Series) SALE
Get the new X5 Led Light Bar with us for a great deal!
Order here!!
Each X5 LED also features a wiring harness with in-line fuse and on/off toggle switch. For peace of mind, X5 LEDs come equipped with Rough Country's 3-year Warranty.
Thanks
Austin
CCOR
706-559-9609
Vendor
Discussion Starter #5 (Edited)
2-INCH SQUARE CREE LED LIGHTS - (PAIR | BLACK SERIES)
Rough Country's affordable set of Black-Series 2-inch Square Cree LED Lights. This all-inclusive kit features everything you need to get going while the compact size makes it perfect for adorning a bumper, hood, roof, or anywhere you can imagine.
Vendor
Discussion Starter #7 (Edited)
50-INCH CURVED CREE LED LIGHT BAR - (DUAL ROW | X5 SERIES)
Click here to order today!​
25650 lumens
285 watts
Contains 95, 3 watt High Intensity CREE LEDs
8 degree spot / 90 degree flood combo pattern
IP67 Waterproof rating
Unique X-pattern design
More LEDs per square-inch than any other light bar
Noise-reducing design helps eliminate harmonic vibration and wind resistance​
Vendor
Discussion Starter #9 (Edited)
10in Cree LED Light Bar - (Dual Row | X5 Series)​
Rough Country's 10-inch X5 LED Light Bar includes a set of spacers to fit 12-inch mounting solutions. Each X5 LED also features a wiring harness with in-line fuse and on/off toggle switch. For peace of mind, X5 LED's come equipped with Rough Country's 3-year Warranty.
Order here!!​
Vendor
Discussion Starter #16 (Edited)
30-INCH CURVED CREE LED LIGHT BAR - (DUAL ROW | BLACK SERIES)​
Stay out later on the trails with Rough Country's 30-inch Black-Series Dual Row CREE LED Light Bar. With a powerful 14,400 Lumens and 180 Watt output, this LED light is a sight to behold. The black panel design offers jaw-dropping good looks that blend perfectly with any vehicle using black accents like grilles, wheels, bull bars or steps!
1 - 20 of 106 Posts
