1 - 12 of 12 Posts
lengthening gooseneck trailer,best spot to cut and lengthen?
I have a 24 foot gooseneck with dovetail. I need to add 5 feet to it so that I can carry both of my vehicles. Both vehicles combined come in at 10000 pounds.
I am interested in hearing suggestions on where is the best "spot" on the trailer to cut it and lengthen it. The rails are 10 inch I beam that is .250 thick. I am using two pieces of 6 foot matching I beam and doing the "step cut" instead of butt welding back together.
The two spots I have looked at is about 18 inches from where the "gooseneck" is attached to the trailer. or two feet in front of the "front" trailer axle. Thoughts and suggestions. Thanks
Vendor
I'm curious about other's thoughts on this too, we have a 18 ft GN that needs to be 25 to put my cabover on it. If someone finds good tech somewhere else please link it here!
This is the way I did the trailer above, I really didn't want to mess with cutting the neck off and lengthening it and I didn't want to lengthen the rear and have to move the axles and fenders etc...So I cut in front of the axles and added 4'.
Fish plating
I took 1/4" angle and plated the inside/bottom of the entire extension
It may not be the best way or the "right" way, but it's the way I did it and so far so good. It's been to TTC last year weighing in @ over 10k and it's been on 10 other wheeling trips of between 100-200 miles. Tows great and haven't noticed any faults to it yet, just make sure the joint has nice fish plating and I added the extra support under the entire extension to make me feel better.
thanks for posting the pictures. That is basically one of the way I was envisioning doing it. Only exception is my trailer is I beam and I was planning more of the cut being "z" cut on both ends of the splice. I have found the following link,http://www.pirate4x4.com/forum/tow-rigs-trailers/612992-stretching-trailer.html which discuss the appropriate ditribution split and there is apparently a formula to figure it out. Did you notice any changes to how the trailer tracked or anything? Obviously turns will be a little different since the axles are further back.
There are no vehicle inspections in oregon. You can pretty much do any changes you want. The only time the DMV will inspect is when bringing in a vehicle or trailer from out of state and then registering it in oregon and even then they only do a vin inspection. (knocks on wood) Hopefully they don't start the safety inspection thing I hear about on the east coast.
When I was reading up on cutting the frame I did alot of searching on how people extend semi truck frames, I don't know if the "Z" cut is the best because it leaves alot of 90 degree corners that might be a stress point and might crack in the future. Also when you fish plate it make sure the ends of the plate are rounded.
My ol man shortened the frame on a 90' 10lug super duty that was loooong. He done the "z" cut but he rounded the corners (instead of squaring them) to make a seem less continuous weld and put a single fish plate on the inside and it has held no problem for bout 15 years 500,000 mi with a cummins and weighing 16,000 pounds as a service truck with an Autocrane service truck bed. Just sayin :)
1 - 12 of 12 Posts
