1 - 20 of 26 Posts
At the risk of not being hardcore, I need to ask if anyone knows the thickness of the windshield glass on a CJ/YJ. Didn't want to ask in non-hardcore since I'm confident nobody is using Lexan in there. I'm shopping for some MR10 Lexan to make my own windshield but I don't know the thickness I need to fit properly in the OEM windshield frame seal.
Yes. Hence the MR10 spec. It comes with the scratch resistant coating already applied to it. It meets some fairly rigorous specs and I am familiar with a few guys that are using it with great results even when using wipers. It is obviously not as good as glass but this is not going on a daily driver, anyway. The bonus is the awesome impact resistance and it is less than half the weight.
So, anyone know the thickness of the OEM glass on a CJ/YJ?
1/4" seems a little thin to me....been a while since I have seen a windshield out of a frame so I'm really not sure. Maybe the molding hugs 1/4" just fine even if it is thinner than OEM?
Banned
there is lots of room in the frame for error as the exterior seal presses into the gap left after the glass is installed.
i measured the glass for you with a open end wrench and 9mm was a touch loose and 8 mm would not fit at all so its somewhere in between 1/4 and 5/16.
were you planing on hard fasteners? or urethane adhesive?
if you go with fasteners it will need to be alot thicker to make up the space the original urethane was in
Andy,
Thanks for measuring. That's awesome. No fasteners....just dropping the Lexan in the frame with the OEM molding.
I noticed you are not on J/K again.....what happened now?
Looks like 9.5 mm is pretty much 3/8" bang on. I'm going to go with that....thanks again.
Banned
the cj frame may be different but the yj uses no molding for "retaining " the glass.
im assuming you are using a full rubber molding with a lock strip built into the front.
the yj uses a "fake" rubber on the interior and a press in strip on the outside that looks similar to the old lock strip rubber moldings.
if it has a old school molding there is lots of room in there for proper retention of the lexan you may have to add some strip caulk to the inside if its a bit loose to stop any water leakage.
if its a yj molding you may have to use fasteners as im unsure f the urethane adhesive will stick to lexan
Moderator
Trying to remember the name, but there is a company selling these ready to go and with teh correct CJ and Wrangler thickness. I am planning to get one to replaced my cracked TJ windshield...
Discussion Starter · #12 ·
There are a few suppliers for this. The problem is that they would cost a fortune to get in Canada. I have competitive pricing for MR10 locally - I just have to cut it to size which is no big deal since it is very easy to work with. I just neede to verify the thickness since I didn't have a glass kicking around to verify.
Discussion Starter · #16 ·
Wow, $350 seems high for a flat piece of lexan. How much does this stuff cost by the sheet?
Travis..
A LOT less. I found 4 x 8's for significantly less than the Speedglas CJ windshield. I also found a couple local Lexan suppliers that will cut to size and I only have to pay for the material used. For me, it is a no brainer.
Discussion Starter · #18 ·
^ Thanks for the heads up but me thinks the winshield not being glass will be a little low on the list of what might be questionable on my vessel.
I cut my sheet with a jigsaw. I put down some masking tape and clamped a straight edge down. Ran the jigsaw down and rounded the edges with a flapper.
I went alittle to thin so it flexs alittle. But I have been very happy so far.
Travis..
Percy also sells blemish speed glass at 80% off that is what I got. just a thin line of bubbles.
$70 makes it look a lot more appetizing. I can measure the speed glass if you want I also have a glass windshield in the mail for my daily driver.
Give me a couple days I can measure them if you still need it.
1 - 20 of 26 Posts
