1 - 5 of 5 Posts
Ok I'm new to this site. I was searching for Ford explorer lift kits made for an IFS front end. Is there a lift that will work out there. I'm not very knowledgeable in the ford world as for I run a Samurai. I've been told Ranger stuff can work but I thought I would go to the best set of sources.....you guys! All we want right now is to put a 31 - 33inch tire on it. I know that we will most likely up grade later because this is a very addictive sport!! Any Suggestions or tips would be great. We really don't want to put a solid front axle in unless we HAVE to. If so then what do we need? Thank you for your help! :grinpimp:
go to explorer4x4.com....you can do a tt and shackles, which will get you about 2" of lift.....or do that and then add ranger BL on top of that PA#853 for the 3" BL or PA#852 for the 2" BL. then you can always drop $1500 on the SuperLift 4" kit. any other questions?
1 - 5 of 5 Posts
