1 - 20 of 27 Posts
<IMG width=300 height=300 SRC="http://www.pirate4x4.com/ubb/uploads/linelock.jpg">
Ok, I bought this electric linelock from Aggro's recommendation. I hooked it up, and hit the brakes, and brake fluid squirted out of the fitting I have an arrow pointing to. After taking it back apart, it became obvious what the problem was. See the next pic:
<IMG width=640 height=480 SRC="http://www.pirate4x4.com/ubb/uploads/linelock2.jpg">
The brakeline doesn't seat against anything. So what kind of fitting do I need? <IMG SRC="smilies/confused.gif" border="0">
That looks like a compression nut. But could that be?
if You are Going to use this Looks Like You need to Adapt it from Pipe thread to flare Common Ace Hardware Shtz,,,, seems like All brake Shtz are Like this!! That sucks they don't send them with the Unit???
IH/Rover Moderator
Dirtrod has it. They look like this:
<IMG width=538 height=340 SRC="http://www.pirate4x4.com/ubb/uploads/flare_nut_fitting.jpg">
Discussion Starter · #9 ·
Originally posted by Old Scout:
<STRONG>Dirtrod has it. They look like this:
<IMG width=538 height=340 SRC="http://www.pirate4x4.com/ubb/uploads/flare_nut_fitting.jpg"></STRONG>
Perfect. Thanks guys! <IMG SRC="smilies/biggrin.gif" border="0">
IH/Rover Moderator
Nice job guys 21 minutes to help out Web daddy! <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0"> <IMG SRC="smilies/bounce.gif" border="0"> <IMG SRC="smilies/bounce2.gif" border="0">
Got mine at Reibes! They have all the good stuff behind the counter! Flared stuff and even some of the off the wall sized fittings! Get it! Lance don't feel bad I did the same thing when I hooked mine up!! <IMG SRC="smilies/biggrin.gif" border="0">
Lance, food for thought..I have a line lock simalar to that..according to all the info. I can find..they are a limited use lock at best. My friend put his to the test..He left it turned on for about 90 sec in his driveway..The bronco started rolling backwards and the Micro unit was very hot to the touch. Some actually say they are not to be left on for more than 60 sec. Just a heads up! <IMG SRC="smilies/eek.gif" border="0">
Lance, the part is called a "seat". I have the same line lock and have left mine on for hours without any problems.
Neckster,
What kind of line locks are those.
Where do ya get em, and how much.
Im thinking about setting up a pair of them to be used as cutting brakes as well as E brakes at the rear.
Originally posted by onetoncv:
<STRONG>lance lets get you hooked up on our dana 300 driveline brake man!</STRONG>
I like this!!!
How large is the disk? Wondering about clearance.
What about cost?
Discussion Starter · #16 ·
Originally posted by H8monday:
<STRONG>Neckster,
Im thinking about setting up a pair of them to be used as cutting brakes as well as E brakes at the rear.</STRONG>
Mine will be used as only a "cutting brake" for competition use. Parking brakes are <IMG SRC="smilies/rainbow.gif" border="0"> and I have no use for an actual parking brake. There was a thread about this unit a couple of weeks ago, and Aggro said that he has left his on for weeks without trouble, fyi.
I got it from Jeg's for about $40.
EXCEPT.....If you leave them on a long time...Your battery will die!! Looks like the board is quicker than me. Good to see you got the right fitting. Or at least a pic of it!
That depends, is it power to open, or power to close? If it were power to open, could be a good deterant.
1 - 20 of 27 Posts
