1 - 20 of 42 Posts
looking into re-doing the suspension on my rock racer and was interested in what people think is a safe size of bolt for lower link. A lot of people are running 1.250 heims with 1" bolts, but that bolt seems way overkill. I am considering the ballistic fab joints with the 5/8 bolt hole. I would of course be running a grade 8 bolt. How many people have broken lower link bolts of this size or bigger? This rig sees a fair amount of abuse, mostly higher speed collisions with rocks and hard link impacts. Rig weighs about 3800lbs and has 40" tires with dana 70 axles front and rear.
i'd say lowers 3/4" bolt uppers 5/8" bolt
i run 5/8" grade 8 for my uppers and lowers but im a 2700 4 banger with fj80 axles.
1" bolt would be stupid overkill
If you buy a good quallity 5/8" Gr8 it will be plenty.
Vendor
I've seen a couple broken 5/8" grade 8 link bolts, I wouldn't run anything smaller than 3/4" (but I'm one of those guys with 1" bolts :flipoff2:)
I have bent [not broke] a 5/8" grade 8 bolt on a lower. Somewhat of a special case, because I have only one lower link on the rear. The joint failed and got clunky and by the time I figured out what was clunking the bolt was bent enough that I had to cut it out.
Marv
i break usa made grade 8 5/8 bolts about once a month. on my upper links with a double shear. i plan to upgrade the joint to a 3/4 soon to stop this. i have 1 grade 9 that has never broke. i use 1" on my lowers.
What benefit is there of using a smaller bolt besides you can get hi misalignment bushings for them. Most Suspensions do not need all of that miss alignment to work. The weight is no different it just " Looks " heavier.
The plus side is you never have to worry about them again.
Discussion Starter #9
benefit with ballistic joints is the joint itself, you can either get the smaller joint with 9/16 or 5/8 bolt or jump up to the 3" joint that takes 3/4 bolt. price is the main difference, and mounting a bigger wider joint. As long as space is available, i imagine the extra price shouldn't be the decider.
3/4 lower...I think we use 9/16 uppers..never busted one yet...and it gets BEAT (well..not SHANNON CAMPBELL beat....more like Tom Campbell beat)..:D
<--- has broken a lot of shit, but never a 9/16" link bolt.
Discussion Starter #12
I don't beat it like Shannon, but try to on occasion:flipoff2: I am always shooting to beat him though.
I run 3/4" lower link bolts in 1.25x1 heims, and 1/2" upper link bolts in 3/4x5/8 heims.
We broke one 1/2" upper link bolt at KOH 08. First time this car has ever broken a link bolt. I'll probably swap it out for a higher grade bolt before KOH 09.
3/4" for all of them, imo. Plenty, but not overkill.
Its great to have all nuts and bolt heads the same size too.
I run 5/8's on everything. 22klbs in shear strength is a lot. Add that it is double shear and I would think that you have to really screw up your design or your driving to break one. I do run 4 links though which better distributes the forces. Never broken a 5/8s bolt. Now that they are all the same size I only need two wrenches.
I wouldnt think the shear forces on the bolt under just wheeling conditions would be great enough to shear even a 9/16". I have seen guys with single or double triangulated suspensions on hard rolls shear 9/16" gr8 though. The axle took quite a bit of a side hit. Im sure the forces on the bolt in that situation are pretty high, and increase as link triangulation decreases.
THE VOICE OF REASON
I have a 4k# buggy with krawlers and I have broken tons of parts, but never any of my 9/16" grade 8 bolts link bolts. I am using johnny joints. Link seperation, and proper torque, and thick tabs have alot to do with broken link bolts.
-Lucas
I run 3/4 bolts on my rockwell buggy with plenty of HP :flipoff2:
No issues yet, search my name for videos if you wana see how I wheel :smokin:
1 - 20 of 42 Posts
