1 - 20 of 138 Posts
#SteerAndStuffBuggy
About to order rest of parts for my link setup and been searching with no avail regarding thread direction on links. Here it goes.....
Is it worth it to have a left and right hand threaded ends for link adjustability w/o removing a mount bolt or be better to just use all right hand ends for ease of carrying a spare that can work all around and have to remove link mount bolt to adjust length. Its not like one would adjust them again after initial setup.
I have left and right, so I can dial it in as I feel it needs. I can change the instant center, anti-squat, etc., to dial in the exact thing I want. You did bring up a downside to the left and right threads, though - the link jam nuts can come loose and the geometry can change. I look at my links while on the trail, and if they pass the witness marks, I move them back, then tighten the jam nuts again.
I like opposite on straight links, tighten the shit out of them and tack the jam-nuts, never given me problems. On links with a bend in them I run 2 rights because you can't spin them anyway and right hand jam-nuts are cheaper.
I had drilled and tapped left and right on everything. If you aren't a puss you can hammer down the jam nuts tight enough they won't move. I loved being able to adjust them on the vehicle for fine tuning.
Rock Stacker
If you go crawling at the mall then run the left/right combo so you look cool. If you break your junk in the middle of no mans land your one right hand spare will fix it.
I would love to see a tire spin off a link and pole vault the buggy into the air. As long as the sorry sob had his harness on.
Banned
Some of us run alumunium links. One of the down sides to having left and right threaded is if your tire rubs your link, and the jam nuts aren't tight, it can unthread your link from the joints.
Let a lady me into putting right/lefts on the links in case she wanted to adjust stuff or change the pinion angle. Ok fine, I protested. A bit later, while running Indy (hard trail) I'm informed of when her jam nuts came loose and the axle was able to walk sideways out of 'center'.
Easily fixed there on the trail, but that was the last time I did left-right threads.
Vendor
I like left and right but mostly for the initial alignment, and it's nice to be able to line it up later when things aren't the same as when they started. In some rigs, alignment doesn't matter.
WOW :shaking::shaking::rolleyes: ....I run left and right Hiem joints it allows me to fine tune the suspension If you cant afford to have a left and right spare you should not wheel a linked rig...:shaking: Sure you could run all right hand thread but that dosent make it the best option...
Rock Stacker
It comes down to personal preference. Left/right is the fastest adjustment and safer method when under load. Right/right is cheaper,more available, and requires more wrenching which also is part of it's safety once adjusted. I don't mind the wrenching as it is also part of the hobby.
1 - 20 of 138 Posts
