1 - 10 of 10 Posts
whats the minimum OD and wall thickness recommended for uppers (and lowers) in a link suspension?
my lowers are 1.75'' .250 DOM, but it was $5.10/foot, i have many other chunks of tube from slider, bumper,exo leftovers and was hoping something would end up usefull. even schedule 40 pipe:D...
incidentally its a wishbone upper, itll have a ccrossbracce to further strengthen...
and its on a somewhat light toyota...not a 5500# scout on rockwells:D...
It sort of depends on what size heims (if you're using heims) you are planning for the frame ends of the upper wishbone? If they are gonna be 3/4", then most inserts I have used fit inot 1" ID tubing. I would say .120" tubing would be the minimum, with plenty of cross bracing.
I imagine the axle end is gonna be a large 1.25" heim or something?
Andy
i was looking at using 1" sch80 smls pipe wall is .179 or maybe 3/4 if it would work? it is .154 wall
bogger welds if this stuff will work let me know i can get this at work and possably get some for you. its just a thought. i am gonna waste so much pipe on my rig:(
jeff
trd and tntoy can lick my sack:flipoff2:
everyone else gets a :beer:
i ended up having just enough to finish the job with 1.75" .250wall and the bracing with 1.75" .120wall. the frame has standard poly bushings and the axle is a 1 1/4" heim...
I'm using 1.25 .250 wall dom for my front setup. It's worked well so far and I've slid and landed on tons of crap.
Easy
1 - 10 of 10 Posts
