21 - 40 of 501 Posts
Banned
Discussion Starter #26
Banned
Discussion Starter #27
Here is some info toploader sent me to add to the list...Thanks for the support in this thread and hopefully it will continue to grow where there will be nothing someone can not find out in this one post about Rock's... :D
Hardware sizes: (I'll add more to this)
Differential studs-7/16"-20 NF
Knuckle bolts(for kingpin caps) 9/16"-12X1.25 long
Drive Flange Bolts(front/rear axles) 1/2"-13X1.75 long
Tie Rod Thread Size 1-1/8"X12
Tie Rod End Castle Nut 7/8"X18
Tie Rod Clamp Bolt 5/8"-18X2.75 long
Tie Rod Taper-Top 1.080 Bottom .9070
Rear Housing end of spindle to end of spindle 80-3/4"
Housing 3.5"X3.5"
SEALS:
Inner Axle p/n SA 42.4
68.23 12.7
A-1205-A-651
Pinion Seal p/n TAC 7521241
Hub Seal p/n 19207-10896684
MFR 97705
Banned
Discussion Starter #28
Another couple and one is 5 ton...whoo
Question Misc Rockwell questions...
5 ton crazy
Help keep this up for then next couple of weeks incase I miss something please.I am working about 70 hours a week trying to get the damn buggy part's bought so I can wheel again... :D
5 ton crazy
bigjeepguy said:
Misc rockwell questions...
This one is really good for the whole rotating the center chunk thing.
we posted the same link :smokin:
Army Technical Manuals for trucks using the Rockwell 2 1/2 ton axle
Army Technical Manuals for trucks using the Rockwell 2 1/2 ton axle:
TM 9-2320-209-20P
Organizational Maintenance Repair Parts and Special Tools Lists
TM 9-2320-361-20P
Technical Manual Unit Maintenance Repair Parts and Special Tools List for Truck, 2 1/2-ton, 6x6, M44A1 and M44A2 Series (Contains Detail blowups of Axle and Chunk assys.)
This manual supersedes M44A1 and M44A2 series data in TM 9-2320-209-20P. Retain TM 9-2320-209-20P for supporting M35 and M44 series trucks.
TM 9-2320-209-20-1
Technical Manual Vol1/3 Scheduled Maintence Organizational Level
TM 9-2320-209-20-2-1
Technical Manual Vol2/3 Part 1/2 Troubleshooting
TM 9-2320-209-20-2-2
Technical Manual Vol2/3 Part 2/2 Scheduled Maintence Organizational Level
TM 9-2320-209-20-3-1
Technical Manual Vol3/3 part 1/4 Maintaince Organizational Level
TM 9-2320-209-3-2
Technical Manual Vol3/3 part 2/4 Maintaince Organizational Level
TM 9-2320-209-20-3-3
Technical Manual Vol3/3 part 3/4 Maintaince Organizational Level
TM 9-2320-109-20-3-4
Technical Manual Vol3/3 part 4/4 Maintaince Organizational Level
All these links are from LOGSA which has most of the U.S. military's TMs online in a PDF format. Click on "Enter the Site" and you can then search for whatever it is you are looking for. The pin numbers for the rockwell manuals are:
027243
071905
032091
034836
048947
048948
048949
048950
048945
Note: these pins are in respective order.
Rockwell Diff Housing Studs, National Stock Number: PAFZZ 19207 7521785
7/16-14, 5/8" thread length.
7/16-20, 7/8" thread length.
1-7/8" overall length.
Banned
Discussion Starter #32
Sweet I was fixing to out to the shop and pull these stud's out to go match tem up at the hardware store.You just saved me some time...thx..and also thank you to everyone that keeps supplying info to this thread.
Yoderboy, I printed out the entire tech manual on how to rebuild rockwells. When I get home tonite I will scan a picture break down of the front and rear and email it to you this weekend.
Dane
looking forward to the axle breakdown pics.. if u got problem wtih bandwith i could host it instead... and dont you agree there should be a rockwell forum??? since thats lots of topic posted up...
