1 - 20 of 26 Posts
http://au.geocities.com/grahamsampson/images/Critter.jpg
http://au.geocities.com/grahamsampson/images/critter1.jpg
http://au.geocities.com/grahamsampson/images/critter2.jpg
http://au.geocities.com/grahamsampson/images/critter3.jpg
http://au.geocities.com/grahamsampson/images/Critterbuildup.jpg
http://au.geocities.com/grahamsampson/images/shinystuff.jpg
Here's a quick list of the jobs we worked through:
Spring UNDER conversion
Rear OME springs in front with overloads and clips removed
3" Chassis extension
front bumpstops moved under chassis
Rancho 99012's all round 13" travel
10" chassis chop at rear
rear buggy leaf
new shackles
fuel tank moved ahead of the rear axle and moved turned around
2.5" exhaust inlcuding stack
2 new crossmembers
existing crossmembers reinforced
traction bars removed
rear axle braced
steering box moved 2" forward
high steering conversion removed - original drag link re fitted
30m of 1 3/4" 0.0106" (2.6mm wall) grade 350 CDS tube constructed
into front and rear stingers, roll bar, siderails and rear tray.
Sierra 1.3 air filter fitted, breathing through firewall
Doof Doof fuel filter and chrome inlet tube fitted ;o)
engine bay wiring loom er, tidied up.
battery moved to under glovebox
sierra washer bottle fitted
Front body mounts replaced with tubing off the stinger due to tyre
interference.
We crossed it up in on the culvert last night and the balance and
wheel travel, especially in the front are amazing. Moving the front
bumpstops in has gained an enormous amount of compression under
articulation in the front. Very much looking forward to seeing it in
the bush.
NICE the tires dont look too big even sprung under
SWEET:D
Roo Bar`
I like your Bar - very purpose built - I would like something for the moose, but it would have to be built out of 6" pipe:D .
I really like the look of the front fender and the way it cuts back to the fireway - those are neat little rigs.
deepmud
is it true that downunder when you flush the water swirls down in the reverse rotation from here in the states??:confused:
Discussion Starter · #17 ·
We do like the Spring unders. there are now 3 cars in the club running 34+ tyres minmal lift and cutting of body.
Yes our water does go the correct way whilst you northeners have a strange way of doing it.;) mind you that is in the houses that have flushing toilets, most of us just do it behind a tree:eek:
thanks for verifying !that just be sure you spin in the correct direction behind that tree
1 - 20 of 26 Posts
