1 - 2 of 2 Posts
III
This may be kind of low tech but bear with me. Is anybody running a Lokar shifter in their rig? I bought one and have not mounted it yet but it seems to me there is only a detent between neutral and third and no detents for first and second. How do you keep it in gear when in either of these gears? (reverse manual valve body c-6)Is it just the friction of the actual gears shifting inside the tranny? This is the only shifter I have found that fits my needs space wise but now that I have it in hand I can't see how it's going to work once it's installed.
Chris,
Don't know what trans you're using, but try manually cycling the gear selection lever on your slushbox and you should be able to feel the internal detents.
Good luck!
1 - 2 of 2 Posts
