1 - 5 of 5 Posts
I am doing a dana 300 swap in to my MJ, I was wondering what you guys did for studs. I need longer ones to clear the spacer and bolts won't work, any ideas? Also, anyone know where I can get some longer studs? Thanks in advance. fawkers :flipoff2:
Though he could not articulate, I think what he means is;
A bolt that would be long enough to reach through the spacer to the D300 will not fit between the tran and t-case.
You could still use bolts but it becomes more time consuming by putting them in the adapter before mounting to the trans.
I got my studs from Orchard hardware. You can get them from McMaster-Carr also.
1 - 5 of 5 Posts
