1 - 2 of 2 Posts
Its an 89 with a 350. The guy is the original owner but is clueless about vehicles. He doesn't know what trans is in the vehicle or if it as a posi rear.
What other options or problems should I look for? Are there any axle or tranny variations on that truck?
Thanks in advance.
Whit
It should have a 700r4 transmission..
The axles should be a 14 bolt semi-floater in the rear and a 10 bolt front..
The tranfercase should be a np241..
Gear ratio could be 3.73 or 4.10 as they were the most common..
As far as the posi or limited slip, then it's a good possibilty because most that I've seen in that year did.. But you won't know for sure until you get it :D
1 - 2 of 2 Posts
