I figured if anyone would have this stuff it would be the ford dudes.. Does anybody have a set af brackets you arent using? I have cash in hand!
Ditto...kwspony said:I have a set off a 78 bronco I ain't using.
Thanks anyway dude.. I need the 78/79 cause I guess theyre different. Im making a crossmember for my new extended arms.wanderer2004 said:Got 77's Sorry
wanderer
The bracket that is between the radius arm [control arm for you non ford folks] and the frame. Thanks! Also kwspony I sent you a PM. Thanks dude!Strong-J said:I may have them?
I pulled a set of axles out of a 1979 f150 (D44rs front and F9in rear) I am not using any off the original brackets/arms... what specifically do you want and I'll snap a picture off it to confirm it will work for you....
78 & 79 are lower hanging that the older ones...el ranger loco said:Thanks anyway dude.. I need the 78/79 cause I guess theyre different. Im making a crossmember for my new extended arms.
One of you other dudes wanna hook me up?
