1 - 4 of 4 Posts
I'm looking for a Corp 14 with 6 lug and 4.10 ratio (the plan is to bolt it into my full size Jeep truck in place of the AMC 20) I need to know the WMS to WMS on one to see if it will work for sure.
Im currently doing this on my J10. I had the AMC20 as well. So far, I shaved the bottom, converted to disk, moved the perches and shock mounts. Im fabing up a cover and hanging it in a day or so. If you want the results, shoot me an email. On the J truck, it it a tight squeeze, cause the springs are 53" from outside to out side, and the is almost the same measurement from drum brake backing plate to drum brake backing plate. I had just enough room to fit a 5/8" Ubolt on the outside of the perch. Will know for sure how it all fits soon. Dennis
If you are looking for a 6 lug 14 bolt, then you are looking for a semi floating 14 bolt. GM never made the full floater in anything other than 8 lugs
1 - 4 of 4 Posts
