1 - 4 of 4 Posts
I am looking for some ideas for mounting my double ended ram on a 95 Ford D60 under a 79 Bronco. The axle has been moved forward 4" and I'm doing a passenger side upper 3 link. I'm trying to find a different way to mount the truss for the ram. It's pretty tight and in order to mount the truss and have room to still remove the diff., it has to be up higher and I'm thinking it's going to get into the front engine crossmember and possibly the harmonic balancer.
I was thinking of making a removable truss of some kind. I am wondering if anyone has done that.
Discussion Starter #3
Maybe build the ram mount off the long tube so only the rod is in front of the diff cover, then to remove the differential you would just have to remove the steering cylinder but the mount could stay.
Thanks. That is kind of what I found. I am going to reply to the original post with what I found.
1 - 4 of 4 Posts
